Mixed valves?
2 replies to this topic
  • Slow and Jerky
Posted June 06, 2012 - 05:29 AM
So I ended up replacing my intake valves with stainless (06 450) I am trying to get the valve clearances figured out. I installed all three valves in the order they were in the packaging, the middle valve has a different part number than the two on the outside so I was careful not to mix them up. But here is my problem, the middle valve has no clearance (even without a shim) and the clearance one of the outside valves is pretty far out (needs a 215 shim).
My original problem was bad valve seals and one valve stem lost the tip so I doubt it is a problem with the seats. My thinking is that those valves were mixed up in the packaging. But I really don't know what the difference is between the middle and outside valves so that is just a guess.
Any ideas?
Posted June 06, 2012 - 05:40 AM
Compare the lengths of the valves. The center valve should be shorter.
What brand did you use?
  • Slow and Jerky
Posted June 07, 2012 - 11:22 AM
They were mixed up, I measured them last night and re-installed. The middle one is a little shorter, the gaps are all about the same now. In theory I just need to get the correct shims and get it put back together.
Thanks!
  • On January 15, 2017
  • 9 replies
  • Hot  36 replies
