Power valves are they worth it!
Posted 04 June 2012 - 08:34 PM
pv are a pain sittin close to ure piston and gunken up just get a 4 banger and there u go u got urself a low rpm bike still though outlet valves wich will doo what? A: give u problems and slow the rpm of the bike. no vavles and it wont run, 4 strokes, so Why incorporate outlet valves on to the motors that run fine with out? to turn them into what theyre not. take the outlet or pv off and its an original 2 stroke with nothin dangling waiting to blow up ur bike and nothing to slow ur rpm.
ANY WAYS what r ur thoughts on Power valves? and if u think they increase performance, why does a cr 500 have none and flog everything?
Posted 04 June 2012 - 10:12 PM
With the whole CR500 thing, it produces similar horespower in the midrange (where peak hp occurs) to the kx500, many dynos say even a little bit more than the kx. But the kx doesnt fall as flat in the upper RPM's where the CR500has to be upshifted if you wanna keep haulin ass, where the kx will be able to hold a gear longer whilst still producing power. I believe this id due to the PV. I dont know which engine produces more off idle.
Edited by Natho, 04 June 2012 - 10:14 PM.
Posted 05 June 2012 - 08:29 AM
For your information the function of the PV is to make more TOP END. It opens at higher rpm to reduce compression as 2 strokes make more top end with lower compression. Quicker your PV opens, the snappier your bike is. So you've accomplished the opposite of what you were looking for...
Posted 05 June 2012 - 08:34 AM
Power valves broaden the powerband, properly set up they will never cost you power. In the case of a CR500, keep in mind that it's a big bore, so they never rev'd very high anyways. This is also why the KX500 had a wider powerband and more power in the later years as they did use a PV.
If you need to remove it because you cannot afford to replace it ~ that's one thing, but removing it because you are looking for that pure two stroke experience, well, ... that's another deal and I do not recommend it. Sure, it's fun to play around with a hard hitting bike, but while your spinning and throwing an impressive roost your competitors will be hooking up and waving goodbye.
Posted 05 June 2012 - 08:49 AM
In my eyes the PV just makes the powerband wider.
Posted 05 June 2012 - 01:21 PM
tribalbc, on 05 June 2012 - 08:29 AM, said:
I though that is not the main operation of a PV. It hardy increases TOP END. I dont mean to get in an anrgument but dont they just alter the size of the exhuast port? i.e low rpm, PV closed small exhuast port high = good torque/crispness. high rpm PV open, ports wide open, good top end power......If the PV was removed wouldnt it retain all the topend, and loose the ability to 'lug' and be torquey and crisp at low rpm?
Posted 05 June 2012 - 03:21 PM
Posted 05 June 2012 - 03:52 PM
Natho, on 05 June 2012 - 01:21 PM, said:
I think we're on the same page but he said he plugged off his PV so I'm thinking permanently closed. If it's permanently open then we will have the opposite effect. No bottom, mid lots of top end.
Posted 05 June 2012 - 04:01 PM
tribalbc, on 05 June 2012 - 03:52 PM, said:
Oh ok, I want him reply to get more info on the whole deal. I wonder how a big bore say 300 Big Bore would go with the PV removed, it would obviously still suffer down low but not as much IMO. The suzuki A TEV exhaust/power valve is very reliable and not as prone to carbon buildup/siezure as some of the other systems.........I could see removing the PV on something like an old KX KIPS system like a mid 90s KX250 if your going for pure simplicity and reliablitiy but IMO with the rm's leave em alone
Posted 05 June 2012 - 05:57 PM
Not arguing at all, so all good!
Think of it this way, the purpose of the PV is an engineering attempt at having your cake and eating it too.
What a PV actually does is "raise" the height of the exhaust port. The higher the port the more top end power you will get (to a point), but this also comes at the expense of low end and how it rolls into the mid range power. So if you did a dyno pull with the PV perminately closed (in the down position) the power will start out sooner, have a decent amount of mid range and then go flat on the top end. Take the same motor with the PV locked open (all the way up) and the curve will not be as strong down low and as it rolled into the mid range, however, at a certain RPM (and it's different for every engine combination) the power will then exceed the closed dyno curve and then continue to make more power up to the mechanical red line.
So the real trick here is to get the PV to open at the point where the dyno curves cross, as it's at this point where that engine design is always making the most power.
Posted 06 June 2012 - 07:19 AM
SOOOOOOOO PV TO MAKE A WIDER BAND LIKE A 4 STROKE . WHY? JUST GET A 4 STROKE IF U RIDE A PV BIKE IT AINT A REAL 2 STROKE IS IT ITS BEEN MODED TO HAVE TORQUE AT LOW RPM LIKE A 4 STROKE SO EFECTIVLY ANYONE RIDING A PV BIKE IS WASTING MONEY ON 2 STROKE OIL WHEN THEY CAN GET THE SAME THING ACTUALY PROBABLY BETTER LOW RPM TORQUE WITH A 4 STROKE.
why bother with pv?
Edited by Zaqster, 09 June 2012 - 01:54 AM.
Posted 09 June 2012 - 01:50 AM
Posted 09 June 2012 - 07:16 AM
why bother with pv?
We all see what you mean, but two strokes with PV are still going to be more snappy and less smooth. Plus, most people have two strokes for the ease of maintenance, cost, and weight. Explosive powerbands are not what everyone wants, even though they ride a two stroke.
Posted 09 June 2012 - 12:25 PM
Snap involves a fast transition from low rpm to high rpm, which can only be optimized with the powervalve. If you remove it, you're hurting low rpm power and slowing down the transition to high rpm power. Also, don't confuse low end power with a 4t, just look at any 2t trials bike. Placement of power is the result of a rider's wants/needs and/or a benefit to certain terrain types. If you like hyperactive input, why aren't you on a 125? If the reason is power, then why aren't you on a 500? The answer is simply that you've found a bike that works for you, but for some reason are unable to undestand how anyone would want anything different from yourself. Believe it or not, there is actually a world out there aside from your own.
Edited by corndog, 09 June 2012 - 12:25 PM.
Posted 09 June 2012 - 05:13 PM
75mx125, on 09 June 2012 - 07:16 AM, said:
I don't agree that a PV makes a 2T more like a 4T, it just improves an already awesome engine design.
Posted 09 June 2012 - 11:51 PM
2 strokes with large width exhaust posts chew rings up in no time as the ring expands into the large exhaust port then gets stuffed back into the piston ring groove. So to make them reliable you would make the port not so wide but then you would drop power...so then maybe you could make the port narrow but taller but then you get a very narrow power-band which isn't really fun. So one answer was to make a tall port but with a type of valve that altered port height.
So the valve would alter port height which in turn would alter exhaust duration etc. You could then run fancy porting or pipes without sacrificing mid range power. Honda most likely achieved power and torque figures they were looking for without the use of the exhaust valve in the CR500 motors.
Edited by Spocko, 09 June 2012 - 11:52 PM.
Posted 13 June 2012 - 10:09 PM
Posted 14 June 2012 - 01:27 AM
Zaqster, on 13 June 2012 - 10:09 PM, said:
Wide exhaust ports cause the ring the bulge into the port. This is well documented and was an issue in early two stroke designs. As stated before running skinny exhaust ports saved rings but flow area of the port was reduced hence the ports got taller. Running taller ports gave you a narrow power band which was undesirable. Exhaust valves vary the port height without the downside of narrowing the power band. Also just to add a bit of bonus info, removing the exhaust valve system completely leaving a large void in the exhaust port will most likely impede the function of the pressure wave entering the expansion chamber. Allowing the exiting exhaust from the cylinder to expand and cool within a larger exhaust valve-less space is less than ideal. You would want the exhaust and its friendly pressure wave to remain hot and fast as it makes it way to the expansion chamber ensuring a high amplitude of the pulse wave.
Edited by Spocko, 14 June 2012 - 02:11 AM.
Posted 15 June 2012 - 07:39 PM
I keep reading in the news about people using "bath salts" and losing their minds. Perhaps you can tell me, are bath salts slang for some wacky new drug, or are people just snorting Epsom Salt to get high.
