Bedunjgi, on 07 June 2012 - 01:55 PM, said:
I found two options to have removable caps on an abs pipe. One is a plumbers test cap that is a cork with a nut & bult that expands it inside & the other is a rubber cap that fits around the end of the tube with a hose clamp. They have them in the plumbing section of hardware stores.
I didnt see that you used the Oatey plug. I have seen other set ups like that but I think the problem was the plastic tabs breaking. Anyone know where I can get an empty battery box the size that eddie is using in his setup? When my Turntech 2.5 A battery dies I was thinking of getting a lightweight tube & cap matching my MRD SSW & making a tool tube out of that with a tiny battery at the bottom. It would look like a dual exhaust & be secure.
