Radiator fan?
22 replies to this topic
  • GlennR
Posted June 04, 2012 - 04:49 PM
I'm planning to install a fan and am looking on ebay. I wonder if a YZF450 fan will fit? Anybody know of others that will fit on my 08' 450?
I'm hoping to get a used one for $20 or less. I figure that I'll only need it in heavy traffic and only slow steep long hillclimbs, so used will be fine.
Edited by GlennR, June 04, 2012 - 04:52 PM.
  • Just_a_trail_rider
Posted June 04, 2012 - 11:04 PM
Are you commuting on your wr?
as far as the hill climbs, if you are moving 5-10mph, that is plenty to cool the engine some.
Why not just get bigger radiators. I just put some of those chinese radiators on my bike. They hold a lot more coolant and I have noticed how cool my bike runs now.
$100 shipped for the larger radiators. Quality is very good.
  • GlennR
Posted June 05, 2012 - 04:02 AM
No commuting, but I can see her running hot from sitting at a traffic light or 3 on a busy day. I'm working on a set of street wheels and figure I'll want to go into cities sometimes.
I ordered a pair of Mishimoto radiators for the DRZ I had last and was impressed with the quality, but I'm not sure larger radiators would really increase the cooling capacity when there's no air flow.
I have only overheated once riding trails. It was a grueling steep rocky trail in the woods. The engine got hot enough that it didn't want to run and got difficult to restart until it had a bit of time to cool down. I could hear the coolant moving into the resevoir. My buddy had a brand new Husaberg 570 which also over heated and lost collant, since it doesn't have a resevoir. We both felt that we'd be adding cooling fans to each bike, but neither have been in that type of riding situation since that day. That was one of my first "real rides" on the WR450 and it left a strong impression about the bike needing a fan. I was concerned that the high temps could have caused engine damage, and that would have really been a bummer on my "new Blue toy". :cry:
  • Stealth13
Posted June 05, 2012 - 06:27 AM
Can you post a link to this radiator? Thanks
  • GlennR
Posted June 05, 2012 - 08:38 AM
Just look on ebay. They are the cheap ones. The DRZ pair was $119 including shipping. I think the WR450 ones were even less the last time I looked.
Posted June 05, 2012 - 12:27 PM
Yep...
exactly...
Here is a picture of the old and new radiators side by side.
  • nuckingfutts
Posted June 05, 2012 - 04:10 PM
Does anyone know if these fit the 426? The part #s are slightly different between the 450 and 426.
  • zibbit u2
Posted June 05, 2012 - 04:43 PM
If you get steel framed 450 rads then yes they should work. I'm running 426 Fluidine radiators on my 04 450.
Posted June 05, 2012 - 06:38 PM
Keep in mind that these radiators are bigger, wider and taller that the stock ones. I had some flatland radiator guards, but they wouldn't fit the larger radiators. The only guards that would fit are the moose racing ones. http://www.mooseraci...t_group_id=7369
I think enduro engineering has the same ones.
However, those chinese radiators are so thick and beefy that you may not want radiator guards.
  • Taxgod4u
Posted June 06, 2012 - 07:34 AM
can you still run the stock plastic radiator shrouds/scoops with the larger import radiators w/o modifying them?
Posted June 06, 2012 - 05:20 PM
Yes, you can. No problem.
the scoops in front of the radiator fit as well. Fwiw, I have a set of scoops from a KTM zip tied to the front. I liked the black ones instead of the white ones. Been there for several rides. No problem.
  • GlennR
Posted June 08, 2012 - 05:00 AM
The fan I was asking about is too large.
I need a 4" diameter fan. Anybody know of a bike that used a little one that size?
  • SPLATT
Posted June 08, 2012 - 04:48 PM
Here you go http://www.spalusa.c...l&item=30103018 You can get it much cheaper on E-bay.
I have this one for mine but haven't had a chance to install it yet.
Edited by SPLATT, June 08, 2012 - 04:50 PM.
  • GlennR
Posted June 08, 2012 - 05:57 PM
I looked at the SPAL fans, but they aren't cheap on ebay anymore. They were about $30, but now they arre $50.
I want a $20 fan. Maybe a EX250 Ninja will fit? I'll let you guys know want I end up with.
  • MaxPower
Posted June 11, 2012 - 04:08 PM
its pretty cramped under the tank
I doubt many street bike fans are going to fit.
I got a spal fan on ebay.I don't remember it being more than 30.
Do a search here. Some guys added fans pretty cleanly.
  • MaxPower
Posted June 11, 2012 - 04:17 PM
Did you install a temp gauge on your bike?
When I first had my Acewell Speedo tied into my junk Electrosport harness I was shocked how cool the motor ran when at speed on the road. When the weather got cooler I had even restricted air flow over one radiator and the bike still had no issue getting rid of heat.
im bringing this up because I know you ride your bike on the road a lot and a good part of the year there in the North Pole the weather is cool
  • tomerb
Posted June 11, 2012 - 07:06 PM
Check out the radiator fan off a WR250 R/X
  • zibbit u2
Posted June 12, 2012 - 09:39 AM
Did you install a temp gauge on your bike? When I first had my Acewell Speedo tied into my junk Electrosport harness I was shocked how cool the motor ran when at speed on the road. When the weather got cooler I had even restricted air flow over one radiator and the bike still had no issue getting rid of heat. im bringing this up because I know you ride your bike on the road a lot and a good part of the year there in the North Pole the weather is cool
If it's cold outside.. I don't ride :devil:
But, so far on a day which was almost (33 C) 90 degree's F, sitting at a light idling I've never seen the temp of the bike rise above (68 C) 154 degree's F. Typically the bike would run at about (48 C) 118 F..... So I guess it's running pretty cool... lol
  • GlennR
Posted June 12, 2012 - 11:59 AM
I ended up ordering a 120x120mm 12V brushless computer fan for $8 off ebay. The only SPAL I saw was $50 + shipping. The used M/C fans all looked too wide or thick to fit. I had a couple of guys on ADVrider say that they've used the brushless computer fans offroad for years with no problems, so I figured I give it a try since they're so cheap.
As noted in posts above the WR450 runs cool while it's moving. I've only overheated mine once while in very steep, rocky, slow riding. I doubt I'll need it often.
After it arrives from China I'll post a photo & let you know how it looks & works.
  • Stealth13
Posted June 15, 2012 - 07:25 AM
What are you using for a switch to control it? Mind posting the links as I would like to get one as well
