Hello i just got a 2006 crf250x i want to make some more power out of it. Will a head pipe off a 2006 crf 250r work on the bike, i did the air box mod and pink wire and also jetted it. i was not sure what cam to use and head pipe and exhaust. i got a 06 head pipe cheap. Just wanted to know what will work the best for tight eastern woods riding. My other bike is a ktm 200 mxc i would like to get more out of my crf250x like my ktm 200.
2006 crf250x head pipe
Started by
trbxj550
, Jun 03 2012 02:52 PM
7 replies to this topic
Posted 03 June 2012 - 03:28 PM
For tight east woods the stock x cam and long headpipe would be better if your using the low end alot. If you pace is fast and your riding mid-top like most 250f's like, the r cam and pipe give a little extended rpm where the x cam signs off. Personally I have set it up both ways and feel you can get use to riding either setup. The R headpipe is more tucked in if your prone to denting the x pipe, it's a good option just for that. For the most part the head pipe is a match for the cam, but it doesn't hurt to mix match if desired. In more open terrain with tall gearing I felt the x cam and pipe pulls the wide gearbox gaps better than the r cam setup. With the r cam I had to wind it up more to catch each shift. what's cool about the little crf is there is so many tuning possibilties to play with.
don't forget gearing as a mod too, if your x is stock you might want to regear for the tight stuff so your riding 2-3 instead of the more gappy 1-2
Edited by highmarker, 03 June 2012 - 03:31 PM.
Posted 03 June 2012 - 04:07 PM
TRBXJ550. I just rejetted my 05 CRF250X. Opened Airbox, opened difusser, left the pink wire alone. 000 to 1000" 42/135/5th position. I ordered a 13 tooth front sprocket and will be getting 51 rear sprocket in the coming weeks. I ride South Jersey tight woods almost exclusively. My Helment Cam vid before the rejet Honda CRF250X & KTM300EXC South Jersey Pine Barrons, Tight Woods Trail, Near ATCO. I opened the air box more after I shot the vid, but the difusser had been opened. I was running a 40/132/4th position at the time with stock gearing.
I am hoping the rejet and re-gearing will allow me better use of the loe end.
What jetting set up are you now running?
Posted 03 June 2012 - 08:12 PM
You got an 06 R pipe? Isn't that the year they had dual mufflers? The 04/05 R head pipes are the only ones you can put on your X... Can't do the 06 or 07 R pipe because of the mufflers. No wonder you got it so cheap, that year oem pipes aren't in any demand
Posted 04 June 2012 - 05:10 AM
My jetting is 140/42/4th postion. i ride sea level to 3000 ft. Gearing is stock. It also has the difuser cut out. Woulld a fmf power bomb and q seris full exhuast system help in power? i would like to keep it quite. I seen on rocky mountain atv that they had a Lexx MXe Slip-On Silencer With Mid-Pipe with the quite tip. Wonder if anyone runs that setup and if so what jetting? Would there be a benefit by putting a R head pipe on it with that slip on or is it just to keep it tucked in not to smash it?
Posted 04 June 2012 - 09:30 PM
trbxj550, on 04 June 2012 - 05:10 AM, said:
My jetting is 140/42/4th postion. i ride sea level to 3000 ft. Gearing is stock. It also has the difuser cut out. Woulld a fmf power bomb and q seris full exhuast system help in power? i would like to keep it quite. I seen on rocky mountain atv that they had a Lexx MXe Slip-On Silencer With Mid-Pipe with the... quite tip. Wonder if anyone runs that setup and if so what jetting? Would there be a benefit by putting a R head pipe on it with that slip on or is it just to keep it tucked in not to smash it?
The R head pipe adds more top end to the X, but takes away from the bottom end. It depends on what kind of riding you do. I ride tight single track, so I'm keeping my X pipe. If I were riding desert, I'd probably go w/ an R pipe
Posted 06 June 2012 - 08:21 PM
You'll notice the difference in the r and x headpipes more with an open uncorked exhaust. With the stock X muffler with baffle installed, even drilled, the greater backpressure in the pipe makes the effect of the headpipe length less noticable.
Posted 07 June 2012 - 03:48 PM
b yo high marker what do you mean gearing 1-2 2-3 would that be the gears your riding in? and how would you go about doing that? rear sprocket, front sprocket tooth change? help sounds like I need to do this..... tks...
