09 450 Knocking noise sometimes
7 replies to this topic
  • Bigdong
Posted June 02, 2012 - 11:29 AM
I keep getting a loud knocking noise every now and then when im racing from the front of the bike/engine area that i cant seem to pinpoint, I cant get it to do it when its ticking over and only seems to be when im in a higher gear and the engine is straining slightly with the torque. Ive checked everything on the outside of the bike but cant find anything loose. Its about the second hour on a new piston.
The knock is a solid knock but im finding it hard to locate since it only rears its head when im driving at certain times.
Has anyone else had a similar problem or any ideas on what could cause this?So far im pretty convinced its the big end but dont want to split cases yet since ive only been out twice on it :cry:
Edited by Bigdong, June 02, 2012 - 02:15 PM.
  • honda424
Posted June 02, 2012 - 05:50 PM
Could be a hot ping, your valves, piston slap, could be your crank bearings..
  • gscx
Posted June 02, 2012 - 06:09 PM
Check to see if your nut that screws to the crank is loose on the clutch side ( I forget what it is called). This same stuff happened to me before and that was the problem.
  • Bigdong
Posted June 03, 2012 - 11:37 AM
Took flywheeel cover off and sound is a definate knocking when pulling flywheel from side to side, theres no up and down movement so im hoping bearings are good.
  • Bigdong
Posted June 04, 2012 - 08:07 AM
Anyone know if yz s make this clunk noise normally when pulling at the flywheel?
  • Bigdong
Posted June 19, 2012 - 11:45 AM
Still stuck with this issue, not sure if this is normal or not.
Posted June 19, 2012 - 12:50 PM
Yes, it's normal. It's the axial play in the right side main bearing that you're seeing.
  • Bigdong
Posted June 20, 2012 - 11:58 AM
Thx,
I can look elsewhere for my problems then =p
  • On January 15, 2017
  • Hot  28 replies
