FCR problems
5 replies to this topic
  • borqueztony
Posted 02 June 2012 - 10:02 AM
I have a serious headache, I installed a FCR carb kit and now my idle is all messed up. I thought maybe I missed something, so I went back through it. I took it apart a few times and found nothing, I switched between 155 and 160 jet and it made no difference, I left it on the 3rd clip. I have a FMF pipe and 3x3 done, no other major mods, and I'm at  2,500 feet. I removed the slow air 100 pilot jet and set the fuel screw 2 turns out. It runs good, but idles high after coming off full throttle thens slowly comes done till it back fires and dies. Any ideas? I played with the throttle cables to ensure they were not sticking.
  • Noble
Posted 02 June 2012 - 11:06 AM
What is the source of the carb kit? New carb? 39mm FCR mx?
Sounds lean. Put the air jet back in.  Air leak?  What pilot jet?  What needle code?.  The main jet will have no affect on your idle issue.
  • borqueztony
Posted 02 June 2012 - 11:10 AM
It's the thumper kit, did everything per the instructions.
  • William1
Posted 02 June 2012 - 11:16 AM
You need to fine adjust the fuel screw. Ensure the throttle cables have a little bit of play.
  • Noble
Posted 02 June 2012 - 11:18 AM
You are going to have to help out a little more than that.  Thumper kit from Thumper Racing? or Thumper Talk? or???
  • Craigo 485sm
Posted 02 June 2012 - 04:01 PM
Presuming it's the 39Fcrmx conversion kit....Did you follow this guide?
http://www.thumperta...ing-the-tt-kit/
