Static sag 20+-5 VS 30+-5? Opinions.
Posted 02 June 2012 - 04:22 AM
Race sag seems to be the same 100+-5mm there about. But RT says 20+-5 free sag and Öhlins 30+-5mm. No wonder the recommendation differs! Who should I "trust" ? I just want the bike to handle like it´s intended to do.
Had 5.0N/mm on my 09 450F in the forks so I combined one 5.0 and one 4.5 for a 4.75N/mm in the fork. And the 60N/mm spring from the 450 just to try! but to my surprise I get 105mm race sag in gear and 33mm static... Which according to ohlins way of measuring indicates everything is great!? but RTs 20+-5 indicates its WAY stiff! I had guessed on and almost ordered a 56... Now I dont know.
Its very stiff compared to stock, but stock was VERY wallovy... LSc Clickers went from full hard to almost full soft but I havent done much testing, fork is soft initial stroke but doesnt bottom out.
Posted 02 June 2012 - 05:16 AM
Posted 02 June 2012 - 01:31 PM
Posted 02 June 2012 - 02:01 PM
Posted 02 June 2012 - 11:43 PM
Be sure to also set your fork sags too. What works on a MX / SX track on spring rates are usually way off for a offroad rider . I like rider sag of 25% of actual travel and 14% static sag. Also +-2mm variance. MX riders have berms to help with turns and while stiff fork springs help with deep whoops they really make the bike suck at turning on flat ground. Also too stiff a fork spring will make riders run too much preload on rear to try to transfer some weight to front to help with turning. This makes for a very harsh ride overall.
Posted 03 June 2012 - 01:01 AM
Answered like a boss.....
Posted 03 June 2012 - 07:51 AM
So I change the rear spring as I cannot get correct sag numbers, but get the correct fork sag numberswith stock springs, would the bike not be unbalanced ?
Or is a balanced bike one that has correct sag numbers, not necessarily spring rates that correspond
Posted 03 June 2012 - 10:32 AM
Dwight: thanks for the excellent explanation! I´m spot on in the rear then. The front not so much... BUT, I think the "all-balls" seals arent the best ones out there!? Dont seem to last and doesnt slide smoothly. SKFs are expensive but I think I´ll give them a try once these start to leak. My static fork sag is 15mm and race is 50mm. I´ll have to recheck as I forgot to relieve them from airpressure.
Stu2: I´ve been thinking about that as well! Since I´ve gone from 52N/mm --> 60N/mm in the rear and only 4.5-->4.75N/mm in the front. But from my limited testing I feel its rather stiff then soft up front.
Posted 03 June 2012 - 10:22 PM
jonsson_, on 03 June 2012 - 10:32 AM, said:
It should have more than 15mm static with stk springs. I would bet you have a lot of stiction either the seals/bushings (esp. if the bushings weren't replaced when the seals done) or r/s fork bound up.
I almost always try to set rear sags up as close to 35/100-105 as possible. Except KTM's & mini's of course.....
doc
Posted 05 June 2012 - 10:39 AM
stock stack:
5 - 36.2
28.12
36.25
34.25
32.25
30.25
28.25
26.3
24.3 b
havent opened up the shock but 36--> 40
Comp side has 40mm faceshims though.
Edited by jonsson_, 05 June 2012 - 10:41 AM.
Posted 05 June 2012 - 11:12 AM
I think I´ve seen a rebound stack posted earlier with all the .25s swapped for .3s. Maybe that was you posting
Posted 09 June 2012 - 10:21 AM
