I recently bought an 05 450 EXC and I am loving it. I have noticed slight oil leakage out of the weep hole on the left side of the head near the water pump. I hear that this means the cam oil seal. I was wondering how hard this is to replace and if its something I can put off for a few years or if its going to get worse quickly? If all it means is adding a couple ounces of oil every couple of rides I will put it off until i need new valves or something...
RFS oil weep hole
Started by
frdbronco8
, Jun 01 2012 10:24 PM
2 replies to this topic
Posted 03 June 2012 - 10:03 PM
It's a simple repair. Fix it and you won't have to think about it. Travis has a good video on this repair. It will take you an hour tops if you have never done it before. Buy the replacement seal carrier w/ the seals already installed. Dave Hopkins has good instructions on how to install the seals in the carrier if you want to save a couple of bucks and not buy a new carrier. New seals and O-rings are cheap.
Posted 04 June 2012 - 09:44 AM
I found this video online for anyone interested. Your right, it looks pretty simple.
Edited by frdbronco8, 04 June 2012 - 09:53 AM.
