Is it possible to build a 20 horsepower xr 200? Via bigger cam, higher compression, pumper carb?, or by using the 218 or 240 kit? What is the best ripping xr 200 ever? I believe the stock xr 200 is about 15 horsepower stock.
Building of a 20 Horsepower XR200!
Started by
XL100allnightlong
, Jun 01 2012 07:32 PM
4 replies to this topic
Posted 02 June 2012 - 12:15 AM
Depends on whether you use crank or rear wheel horsepower, Honda claims 19hp at the crank, some dyno measured rear wheel HP for a stock engine at only 12. Two types of dynos; brake and inertia. The first is the most accurate, the second easiest to use. So maybe absolute numbers should not be the criteria but rather a percentage gain over stock measured on the same dyno.
It is possible to achieve 25-50% power gains via bore, stroke, compression, cam, carb, and exhaust. For trail riding bottom end is better than peak power and a properly modded XR200 (218) engine will produce more torque than a stock XR250R. That power in the lighter 200 chassis makes a nice woods weapon. If you want a race bike then HP may be important and there are other engines better suited for that use.
Posted 02 June 2012 - 06:59 AM
I was thinking hp at the crank. Honda's claim of 19 seems a little high! I also love torque as I own a 02 xr400. But I am looking at adding a xr 200 to ride tighter trails and to get better gas mileage. That 218 kit sounds nice, does it cost a arm and a leg? Does it make an extra few horses?
Posted 02 June 2012 - 09:37 AM
Posted 03 June 2012 - 02:26 PM
Does anyone have an update on powroll deliveries? I have contemplated a stroker,but saw tons of posts about them not shipping parts on time,and not answering phones
