Ohlins front forks and shock
Posted 31 May 2012 - 04:24 PM
I see they are doing well in Europe on the Yamaha's. I have a Yamaha 450, and I am thinking of purchasing a set next week. They look relatively easy to service and look like they have all the upgrades. I believe the package with the coatings, cost about the same as KYB components with valving, springs and coating, so the price seems reasonable, and I will have a spare set of suspension..
Posted 31 May 2012 - 07:38 PM
Last year I had the Ohlins TTX shock on my -11 Yz450F and was happy with it in the beginning but after 15 hours it started to feel strange. My Ohlins serviceguy did a service to it but still after that it never felt really as good as it was when new. Faded very fast and did not react to clickers as it did when new.
Since Ohlins started with this TTX thing I haven't really been as a big of a fan as I was before.
I haven't tried or seen any 2012 stuff in person , so can't comment on that. But Ohlins is supporting some of the factory Yamaha guys in Europe so they should get alot of feedback and knowledge to produce good stuff for the yz450f.
Personally I think the Yamaha stock KYB SSS suspension is one of the best stock suspensions out there. A really really good base to start from. Send to a good suspension guy and you will be happy with it.
But ofcourse the Ohlins stuff is cooler and nicer to look at.
I dont know what level you are on or how much suspension experience you have but many people think that if you buy a Ohlins suspension and set everything up for your weight and measure sag everything will be perfect ! But its not as easy...the Ohlins suspension is an awesome base to build from but as any suspension you need to work on it and try different settings before it really gets to that super level. I remember back in 2008 I had Ohlins fork and shock on my -08 crf450 and worked on it alot, and when I found that special setting I was in heaven ! By far the best suspension I've ever had !
Posted 31 May 2012 - 11:59 PM
Plus, it seems that the Ohlins makes the bike track even straighter and bettter, from down the straight, to through the turn.
I read in MXA a few months ago, that the stuff is good on a YZ 450, but I wanted some real world experience. They are a lot of coin, but like I said, by the time you get the valving, springs, link and coatings on the stock stuff, they really are not any more money.
Oh, they make the shock like 2 mm shorter, so you get the same effect as the link, but the suspension is already set up for the flatter layout.
Posted 01 June 2012 - 03:31 AM
Posted 12 June 2012 - 04:59 PM
I thought the bike turned well stock, but resisted sliding. Now it turns better and I can light up the rear like the 09.
Sent pics of my riding. With my weight and how I stand on the bike, we electred to forgo shortening the shock.
Haven't raced it, and that will be the true test. Ill take crapy stuff AND a win over Great stuff and a loss.
Edited by honda907, 12 June 2012 - 05:04 PM.
Posted 18 June 2012 - 04:16 PM
Quote
Good luck
Kent
Posted 20 June 2012 - 02:18 PM
Dead Eng Start, on 18 June 2012 - 04:16 PM, said:
Good luck
Kent
David at Fast Bike Industries, the guy in western NC, set me up. Probably the same people.
Posted 24 June 2012 - 09:59 AM
It is really good, untill I revalved my stock kayaba shock and added more rebound it was by far the best shock ive used,
I have a 2011 yz 450 with a reva;ved kyb shock and its close to the ttx but not as good
Posted 12 March 2013 - 01:33 AM
Rider: 88 Kg with gear (194 punds)
I'm Running a TTX 44 Shock (YA1294 with a 56 N/mm spring) and the stock Kayaba SSS Fork with the 4.6 N/mm stock springs.
I have already ridden a for a year. Have not yet found a good set-up. It's difficult to really feel the difference. The Yamaha is a really sensible bike, to track, conditions and riding style. Everything has to be in good condition, the tires, the chain, the controls, the right handlebar... the RIDER condition.
Is it worth buying a Öhlins Shock? I cannot answer, but one thing is for sure, the stock KYB suspension offers a lot of possibilities and is as difficult to set up as it is with the Öhlins.
One thing I have learned, don't expect to put an Öhlins and that the bike behaves as you wish.
Follow us:
