Size of seal needed urgently
11 replies to this topic
  • Shawn250
Posted 30 May 2012 - 04:59 AM
Do anyone know the size of the seal that goes around the kick starter shaft for the KX 450 ?
Part number is 92049 - 1541
No stock of the part here and I cant get from a seal shop without removing it , dont want to remove it as it will be damaged and if i cant get a replacement then i cant ride .
If I cant get seal size then I will order it from Japan and wait , at least the leak is more of a sweat so I can ride with it .
  • D-K
Posted 30 May 2012 - 08:49 AM
20x30x7
  • Shawn250
Posted 30 May 2012 - 11:31 PM
Thanks D-K
May i ask where you managed to get the info as I could not find it anywhere ?
  • D-K
Posted 31 May 2012 - 02:45 AM
I could tell you, but then I would have to kill you.
It can be found on microfiches under "engine covers" http://www.motosport...ENGINE-COVER(S)
  • Shawn250
Posted 31 May 2012 - 11:42 AM
thanks .
Also noticed it is printed on the seal .
Managed to get a new one and fitted it .
  • D-K
Posted 31 May 2012 - 09:11 PM
Great, but it was not the part no. you said. Where did you get that number?
  • Shawn250
Posted 01 June 2012 - 04:43 AM
Part number is correct , the seal i got is OEM in the packet with that part number from Kawasaki .
I have access to Kawasaki Parts diagrams online , like the dealers have , because of the work I do .
  • D-K
Posted 01 June 2012 - 06:08 AM
92049-0134 is the part no. I get.
  • mx317
Posted 01 June 2012 - 04:29 PM
This Kawasaki 92049-1541 SEAL-OIL is also used on these models and components:
2001 KSF250-A15 Mojave 250 CRANKCASE
2002 KSF250-A16 Mojave 250 CRANKCASE
2003 KSF250-A17 Mojave 250 CRANKCASE
2004 KSF250-A18 KFX 250 Mojave CRANKCASE
2006 KX450D6F KX450F ENGINE COVER(S)
2006 KX450D6F KX450F (European) ENGINE COVER(S)
2007 KX450D7F KX450F ENGINE COVER(S)
2008 KLX450A8F KLX450R ENGINE COVER(S)
2008 KX450D8F KX450F ENGINE COVER(S)
2009 KLX450A9F KLX450R ENGINE COVER(S)
  • D-K
Posted 01 June 2012 - 11:55 PM
Is there a difference in size of the seal on the older models. I was looking at the later models. O.P. never stated the year.
  • Shawn250
Posted 05 June 2012 - 05:48 AM
just checked now , the part number changed in 09 but is the same size as earlier models , dont know why they changed it .
  • D-K
Posted 06 June 2012 - 12:05 AM
Ok, must have been either a different supplier or a different material.
