Front Wheel Slide
Posted 29 May 2012 - 07:13 AM
2008 YZ450
Triple clamps up 12 mm in clamps
.50 fork springs (I just went from .48 to .50 and I like the .50 much better but the push was the same on both the .48 and .50's)
102 mm rear sag
MX51 front and rear 12 PSI
Running SPI DDT Gen 2 and I can post my set up if necessary.
Thanks
Posted 29 May 2012 - 07:38 AM
Edited by originalmonk, 29 May 2012 - 07:39 AM.
Do you feel the forks "wobbling" when cornering?
Edited by TommyZ, 29 May 2012 - 07:41 AM.
Posted 29 May 2012 - 11:38 AM
shockdoc, on 29 May 2012 - 07:28 AM, said:
doc
Ok, Ill try it. Thanks
originalmonk, on 29 May 2012 - 07:38 AM, said:
210 lbs without gear and its a brand new MX51 12 psi
No wobbling feeling at all.
Posted 29 May 2012 - 01:55 PM
Posted 30 May 2012 - 05:00 AM
I sounds to me like the front end may be pushing out and not sliding out. Pushing in the front is usually caused by front too low (rebound too slow, forks too high in the clamps, springs too soft, rear end too high and so on) Basically the front wheel is trying to turn a tighter radius than the track is capable of holding. You compensate by sitting farther back and slacking the front end so it will not try to turn so sharp.
Posted 31 May 2012 - 11:26 AM
tpars121, on 29 May 2012 - 07:13 AM, said:
2008 YZ450
102 mm rear sag
Thanks
You wanna go a little softer on the compression and maybe a little more rebound(1-2 clicks) your forks shouldnt be up all the way at 12mm either.
good luck!
Posted 31 May 2012 - 01:01 PM
MX28, on 31 May 2012 - 11:26 AM, said:
good luck!
Thanks, I want to make slow adjustments so I think I'll try moving the forks to 9MM up and two clicks on the rebound to start with.
Edited by tpars121, 31 May 2012 - 01:02 PM.
Posted 01 June 2012 - 08:15 AM
As for the MX51 that tire gets very mixed reviews. IMO it is bad on hard pack and bad in the wet. Loose dry dirt it is pretty good. When the 756 was discontinued I tried a couple and didn't like them. First switched to the MX31 on front, and have since moved to the M403. Your terrain, riding style, bike, and preferences may be different but that was my opinion.
Posted 03 June 2012 - 10:27 PM
Edited by Dwight_Rudder, 03 June 2012 - 10:32 PM.
Posted 04 June 2012 - 03:35 AM
Posted 04 June 2012 - 03:56 AM
Posted 04 June 2012 - 07:47 AM
Posted 04 June 2012 - 04:07 PM
mog, on 04 June 2012 - 08:00 AM, said:
An intermediate tire is going to see some hardpack as well as soft terrain conditions, its just not an overall good predictable tire. I'm not sure why your defending it, unless you soley ride wet, tacky soil, it is garbage.
Posted 04 June 2012 - 05:44 PM
