As soon as i turn the fuel petcock on, and the entire time I'm riding, fuel just pours out of the hose that comes off the the very bottom of my carb. What does this mean?
Float bowl drain leaking heavily
Started by
TacoPower
, May 28 2012 12:13 PM
4 replies to this topic
Posted 28 May 2012 - 12:22 PM
Sounds like it may be a stuck float. Try tapping on the side of the carb/float bowl with the plastic end of your screw driver and see if it stops.
You did ensure that the drain hose screw is tight right?
Edited by mikewrf18, 28 May 2012 - 12:23 PM.
Posted 29 May 2012 - 11:21 AM
I took the carb off the bike and opened up the float. Sprayed carb clear all over it and cleaned the needles. I also tested the seating on the intake of fuel by hooking up the gas tank to the carb and pushing the float up and down. When I do this, it works properly (no leak when i push it up, and when i let it down, gas flows in). Is this telling me that the seat is good? Or is it possible that Im just pushing it up harder than what happens normally?
its a 2005 yz125 stock carb
Chas_M, on 29 May 2012 - 07:14 AM, said:
What bike and carb do you have?
Posted 30 May 2012 - 11:14 AM
This is generally caused by either a dirty needle and seat, a worn needle and seat, or a mis adjusted float. Most of the times if the carb has never been taken apart we can simply and carefully remove the float and seat and clean it. This will remove any dirt and grime leading to the seat and the float will remain operational. If this does not help is when we have to start taking float measurements, this helps if we have repair manual all the float level specs are in the manual. Generally if we press the float down with our finger we apply more pressure then the weight of the float would press. The float is submerged in fuel and the float tries to rise to the top thus shutting the fuel flow off with pressure. It is a minimal amount, we can test this by hooking up a fuel line or blowing air into the fuel intake. When the seat is closed we should not be able to blow through it or allow fuel to enter the bowl. And this can generally be test with the weight of the float pressing against the seat.
Hope this helps.
Hope this helps.
