Helmet Cam Needs
Posted 27 May 2012 - 07:25 PM
Posted 27 May 2012 - 07:45 PM
Posted 27 May 2012 - 08:05 PM
RedRider31, on 27 May 2012 - 07:45 PM, said:
Posted 27 May 2012 - 08:17 PM
I just turn mine on before I put on my helmet and ensure it's in video mode. Before I get going, I know I just need to push the top button once to start recording. Just have to trust that it's working, or ask your buddy if the red light's flashing!
Posted 28 May 2012 - 07:44 PM
Posted 28 May 2012 - 08:17 PM
Yamaharider574, on 28 May 2012 - 12:26 AM, said:
Like:
-Real easy to know when it's recording or not. Switch forward = rec, back = standby.
-Low-profile. Sits close to the helmet and out of the way, rather than hanging off just waiting to catch a branch.
-Rec/Standby beeps are plenty loud. Unless i'm really haulin ass, I can hear the status beeps from it.
Dislike:
-Rolling shutter. Causes some weird effects at speed, and makes grabbing still images interesting.
-Power-up delay. This has been addressed with the newer units, they go into sleep-mode when you slide the record switch to standby, then wake up when you slide it forward to record. Mine, you have to press the button on the back to turn it on, then slide the switch forward to rec and wait for the beep.
-No preview... again, addressed wih the newer units that can use a mobile device as a preview and adjust settings through that.
There's some other mechanical issues I have with it... the o-ring seal around the lens doesn't fit real well. I replaced the O-ring with one that's the right size and haven't had dust/moisture ingress problems since. My other major design complaint is the one single thread-forming screw they used to hold the lens cover on. Pull that tiny screw out once and the threads come right out with it. Really needs a threaded insert and a machine screw in there. Again, the newer models may have addressed this problem.
Posted 30 May 2012 - 12:01 AM
SnowMule, on 28 May 2012 - 08:17 PM, said:
Like:
Dislike:
Posted 30 May 2012 - 04:30 PM
-John
Posted 02 June 2012 - 07:32 AM
Posted 02 June 2012 - 07:54 AM
Posted 03 June 2012 - 07:30 AM
they also have a wifi backpack now so you can control the camera via your smartphone and your friends can watch you ride!
it can transmit the video from your camera directly to the internet via your phone
i see the liguid image has that same wifi/phone feature...
I thought the contour had a small lcd as well, i know one of them does
Posted 03 June 2012 - 08:58 PM
Posted 04 June 2012 - 11:13 AM
http://gopro.com/hd-...c-remote-combo/
I've been debating on getting some for our cameras, however upgrading to the Hero 2 will be happening first.
Posted 04 June 2012 - 11:27 AM
CANNOT WAIT to get one of these wifi backpacks + the app for my phone when it's available!
Posted 04 June 2012 - 12:10 PM
Edited by RedRider31, 04 June 2012 - 12:11 PM.
