Here's what I found.
Cam tower loose.
Cam chain so kinked up that it wouldn't even fall down in the chain hole.
OEM tensioner flattened like a pancake
Further down..
The bearing collar on the crank had eroded something fierce. It almost looked like it was a bad casting beneath where the bearing rollers ran. There must have been .030-.050" of slop in the bearing.
The boot where the white chain guide rests in the case had the upper portion of the tab broken off. The oil pump pick up hold down had one of the fingers cracking off of it too.
But I think the root of the problem was the silicone that had plugged up the oil pick up screen.
The spark plug tube had come loose for whatever reason. The dealer that had their hands on it last tried to silicone the tube back into the head. A big flat piece of the silicone had come loose and worked its way down to the bottom end and plugged the pick up. Now, what further plugged the pick up is a guess because of the SAND, metal shavings and other random shit, its impossible to tell what caused which problem.
But, What I did find was a Hot Rods 3mm stroker crank, the rod was still good. The bore was edgy to say the least. The piston was worked over by the metal in the oil. Which was sad in and of its self because it was a JE with probably only a couple hours (Id say less than 20).
So we needed a cylinder and a piston, a main bearing kit for the crank (they come with a new collar) gaskets, chain, MCCT, new hold for the pick up, Oil pump etc..
Owner decided to go with the 100mm big bore to go along with his 3mm stroker which takes the engine out to 511cc. The compression worked out to 12.67:1. I ported the head to flow a bit more for all the Cubes...
Holy crap that thing is fast! It doesn't sign off the way I thought it might either. It just kept pulling and pulling. I had to shut it down since I was in the neighborhood, but the throttle response was instant and the front wheel just claws at the sky with ease.
It kicks easy, fires the first kick too.
Pretty proud of this one.
