hey all,
my yz250 seems to be self propelling when at closed throttle, I'm thinking it could be jetting related although its strange, when I put the bike back together after machining the head for squish and cc'ing to bring the compression back down it ran fine and didnt do this, but now after maybe 2 hours use its now doing this, Ive had this happen before when I had a higher compression head,
could this be jetting if so where would I begin to start to rectify the problem?
the bike is a 2009 yz250, Pro circuit R304, V force V3, head squish 1.22mm, and ran on 98 octane fuel.
any help would be much appreciated.
2009 yz250 - at closed throttle the bike self propels in blips every 1 - 2 seconds
Started by
timo38
, May 27 2012 01:19 AM
2 replies to this topic
Posted 01 June 2012 - 08:38 AM
I havent seen to much of this come through the shop. When saying it self propels are we saying that the bike will rev up? If it is I would suggest perfofming a compression test and determine what we are at. Also try dropping down to 87 octance and determine if the problem is still happening. What are we running for a plug, oil mixture?
Posted 03 June 2012 - 01:56 AM
it will just kind of go "gung" and jerk forward slightly,
the oil mixture is 40:1 and the plug is a 9 I've tried both iridium and normal and both seems the same, I'm going to try an 8 tomorrow.
how many psi would standard comp be?
