2012 WR450F headlight
11 replies to this topic
  • n16ht5
Posted May 26, 2012 - 04:55 PM
How is light output compared to the 07-11? Is anyone interested in trading?
  • tomerb
Posted May 26, 2012 - 06:16 PM
I just put one on my 2011 WR450. It's much better than the one that came on my 2011 and would probably be great with a 35 watt HID. Also it's not plug and play!! The one thing that's much better is that its about one inch higher off the fender so theres a lot less reflection off the fender.
  • n16ht5
Posted May 27, 2012 - 06:44 AM
Where did you get yours? How much?
  • tomerb
Posted May 27, 2012 - 10:35 AM
I got it at my local dealer for about $100 for everything.
  • Just_a_trail_rider
Posted May 27, 2012 - 06:49 PM
What does it matter how much light it puts out. Pretty much everyone I know has already done the $50 HID conversion. You can get the maximum amount of light regardless of the year of the bike.
  • Home Skillet
Posted May 27, 2012 - 06:52 PM
How about this BAJA Design LED light?
http://www.bajadesig...ace-Light-Black
  • n16ht5
Posted May 28, 2012 - 06:23 AM
I have HID. A better reflector pattern in the headlight will more effectively light up the trail though.
Dang that squdron is spendy
  • Home Skillet
Posted May 28, 2012 - 08:03 AM
Yeah it is. Especially when you can buy a pair of those 4 spot LED lamps for $199.
Cycle News has a test on the '012 WR and they said the OEM was marginal for night use.
  • supermega1
Posted May 29, 2012 - 03:40 PM
I've ridden with it at night and its actually pretty decent. Better then previous years stock lights (compared against an '03 when riding). I wouldn't bomb 70 mph through the desert with it but was pretty comfortable doing 30-40 mph down the trail.
  • T_Olie
Posted June 15, 2012 - 07:13 PM
You guys that have done the HID conversion did you have to change the stator to keep the battery life longer than 1 hr. I have a 2008 with a 35 watt hid kit that is wired threw a on off switch directly to the battery. Works good but kills the battery. Now I have the new 2012 and wanted to do a HID on it. Any info would be great.
  • Lumberjack450
Posted June 15, 2012 - 08:27 PM
I'd like to HID my 12 too... will it draw too much if I also have an HID helmet light wired into the system already?
  • Lumberjack450
Posted June 15, 2012 - 08:29 PM
For the OP - it is quite good in my opinion. Done several high speed desert runs at night. However I have 20-10 vision so you old guys may need more light :devil:
