Dr350 cam chain noise?
Posted 24 May 2012 - 06:30 AM
Posted 24 May 2012 - 02:23 PM
pulled off the clutch cover & the primary drive nut was loose.
Posted 24 May 2012 - 05:23 PM
Posted 24 May 2012 - 06:48 PM
Posted 10 June 2012 - 05:30 AM
you will need:
possibly a new clutch cover gasket
2 new 8mm crush washers for oil banjo fitting
4 new sealing washers for clutch cable bracket screws
the cam chain adjuster is automatic.
Posted 10 June 2012 - 07:55 AM
plugeye, on 10 June 2012 - 05:30 AM, said:
you will need:
Posted 10 June 2012 - 09:25 AM
Jhawins, on 10 June 2012 - 07:55 AM, said:
how else would know the primary drive nut was loose? its accessed through the clutch cover, you'll need to clean the threads & loctite it
Posted 10 June 2012 - 10:38 PM
Posted 19 June 2012 - 11:12 PM
plugeye, on 11 June 2012 - 05:24 PM, said:
Problem is the ticking noise is still there. Does anyone have any other ideas?? Does the cam chain stretch and need replaced like the drive chain?? Can I check it easily? I need help.
Posted 19 June 2012 - 11:18 PM
