trouble with yamalube
18 replies to this topic
  • mxer928
Posted 22 May 2012 - 04:59 PM
Has anyone had trouble with the bike running rich on yamalube?  I had been running maxima synthetic with no fouled plugs and bike ran good started 1st kick everytime.  I switched to yamalube with the same ratio, 42:1 and have got 2 fouled plugs within 1 tank of gas.  It just seems to be running richer.  Any thoughts?
Thanks
  • Team Craig
Posted 23 May 2012 - 06:55 AM
I have ran yamalube 2-r synthetic in my bike since purchase and love the stuff. Just put piston and rings in the bike after 2 years of heavy riding and internals were very very clean. On top of that I have never fouled a plug in my bike. Nothing buy thumbs up on Yamalube 2-r
  • rjpjnk
Posted 23 May 2012 - 07:32 AM
What is the difference between the Yamalube products 2-R and 2-S? I realize the 2-R is the good stuff, but I was wondering what exactly is different in the formulas.
  • hackman162
Posted 23 May 2012 - 08:18 AM
2-S is used for injectors.
  • rjpjnk
Posted 23 May 2012 - 08:43 AM
I know, but do you know what the difference is?
  • JFielder23
Posted 23 May 2012 - 12:54 PM
When I first bought my bike (in 2003) I ran Yamalube.  I fouled plugs like it was going out of style.  I switched to Amsoil and I haven't fouled a plug since.  Now that I've learned a lot more about these bikes I know that the proper solution would have been to adjust the jetting, as the bike comes pretty rich for trail riding.   Now, even with my jetting adjusted better, I still run the Amsoil though.
  • rjpjnk
Posted 23 May 2012 - 03:33 PM
I don't get it. I ridden a yz125 for the past two years and have never once fouled a plug, and I don't even ride it that hard. I've used both Yamalube and Bel Ray H1R both with great results. I don't understand why do so many people seem to complain of 2 strokes fouling plugs.
  • cr250_gus
Posted 23 May 2012 - 03:42 PM
yea yamalube runs a bit richer, just put less mix you should be good
  • jason white
Posted 23 May 2012 - 06:59 PM
yamalube 2r 50:1
I tryed 40:1 and 44:1 and was way to rich for me. The owner of my yz was running it at 40:1 and said he fowled a couple of plugs so I went with my previous experience. I went with yamalube because he was running it. After this I may go back to amsoil. Also I ride single track and try to keep fresh packing in my silencer.
  • mxer928
Posted 24 May 2012 - 03:50 AM
Should I not be running the 2S kind?  Thanks for all the replys.
  • rjpjnk
Posted 24 May 2012 - 04:28 AM
What kind of bike? As the poster said above, 2S is for oil injection systems, though I have run it as premix in a pinch.
2R is their "high performance racing" oil and is the one you should be running if you are premixing, and definitely if you are running a modern bike with power valves.
  • racer651
Posted 24 May 2012 - 09:29 AM
I run it at 32:1 without any issues. Never fouled a plug and it don't spooge. Proper jetting and head squish is the  trick.
  • dezracer96
Posted 24 May 2012 - 03:50 PM
+1
  • flapwick
Posted 24 May 2012 - 08:09 PM
I have a 2004 YZ125,a 2005 YZ250,a 1977 YZ100,and I run Yamalube 2R in all three of them at 32:1.None of these bikes have ever fouled a plug.Not even once.  Running 2S may be at least part of your problem.
  • shrubitup
Posted 25 May 2012 - 11:54 AM
Try 2S at 32:1. 42:1 puts more gas into mix making it run cooler. Nothing wrong with 2S in a pre mix bike.
  • rjpjnk
Posted 25 May 2012 - 12:18 PM
Then why does 2R cost more than 2S?
2R claims to be more suitable for power valve equipted bikes at least according to Yamaha's advertising.
I would really like to know the facts though. What, if anything, is better about 2R.  Surely this info must be out there somewhere.
  • shrubitup
Posted 25 May 2012 - 12:29 PM
Eh, a 2S torn down motor is not messy and the motor does not blow up when 2S is being used. Use 2R if you actually race.
  • rjpjnk
Posted 25 May 2012 - 12:34 PM
Are you saying that motors that use 2R are more messy and blow up more that those that use 2S?
This seems completely backwards. Why would anyone use 2R then?
  • shrubitup
Posted 25 May 2012 - 03:59 PM
No. I am saying there's nothing wrong with 2S for purposes other than racing.
