Whats the best way to increase the top speed on my 1981 xl185s?
9 replies to this topic
  • saxman
Posted 21 May 2012 - 05:46 PM
I recently bought a good looking and awesome running xl185s, but want to increase the top end so that i can go on mor roads with it. Ive thought about the idea of putting a smalller sprocket on back and larger one on front, but is there a better way? Will this make much of a difference? And if this is a good idea, how big should i make the sprockets? right now its got a 56 tooth on back and 13 tooth on front. What should i do that allowsme not to spend a fortune??
  • ickfinger
Posted 06 June 2012 - 08:39 AM
i would try a larger front sprocket first, its cheaper and easier to swap back if you dont like it. Dont go too drastic, off road performance will suffer
  • Motosprtman
Posted 08 June 2012 - 06:49 AM
check sprocket specialits dot com and see what the OEM sprocket sizes were - the go hunting for best price etc. Yo can squeeze a wee bit more power out by using a 428 chain vs a 520.
  • NORTY
Posted 16 August 2012 - 11:29 AM
Sprockets and nitrous! Bore it out too.
Seriously,Just leave it alone and ride it locally. Get another/bigger bike for longer trips.
  • Chas_M
Posted 17 August 2012 - 05:54 AM
The existing 13/56 gearing is extremely low.  I'll bet that the gearing could be upped quite a bit without destroying trail riding abilities.
  • MindBlower
Posted 27 August 2012 - 07:54 PM
1t in front = 3t in back.
So 13/56 is the same as 14/53 or 15/50
Try a 14t front first, or if they are cheap get a 14t and 15t.
Gearing does make a big difference as long as the bike has the power to pull the higher gearing.
  • yyz79flh
Posted 26 November 2012 - 07:43 PM
a bit late and don't know if this will help much. i have a xl500s and what i did was got a 13 and 15 front sprocket. i keep the 13 on for most of my close too home riding and trails. when i want to go do a bit of longer riding i swap out the 13 for a 15. also check out this website to help with the what ifs for sprocket changes
http://www.gearingcommander.com//
Edited by yyz79flh, 26 November 2012 - 07:43 PM.
  • capt justin
Posted 26 November 2012 - 08:03 PM
I believe you have your gearing incorrect
13/56  is almost the same as 14/59 or 15/62
if you go up one on the cs then you must go up 3 on the rear gear to be equal
to answer the question 14/52 is a big diff on top speed
  • Phil Davy - Leatt
Posted 26 November 2012 - 08:35 PM
I used to race the ATV nationals on a hand built frame with that same engine in it in the 200cc pro class.  (really not much to brag about) But with everything I did to it bto give vit more power I would say that the big bore piston was the best. And you'll neede a little more power to pull the taller gearing. Try drilling a few holes in the air box as well. Good luck. But note, no matter what you do to it it will never be as fast as you'd probably like.
  • Lair
Posted 26 November 2012 - 08:38 PM
Step one: Put it in the back of your pickup.
Step two: Drive the pickup really fast.
