Hey all,
Ive got a 10' 450. What would cause coolant to drain out the little hole on the bottom of my water pump cover, or actually its the right side case under the water pump? Is it just a seal? what have I got to do to change it?
Ive got the water pump cover off and the seal look good, but it looks to be further out than the hole in which the coolant would drain out of, thus making me think there is another seal past that one.?
Thanks for the input
coolant issue
Started by
islandkawi
, May 21 2012 05:17 PM
2 replies to this topic
Posted 21 May 2012 - 06:02 PM
Since you have the cover off. Take the nut off inpeller pull inpeller off of shaft and replace the seal right behind it.if the deeper seal was leaking oil would prob come out.
Hope this helps
Ernie
Hope this helps
Ernie
Edited by gonzokx, 21 May 2012 - 06:04 PM.
Posted 22 May 2012 - 09:29 AM
anyone have any tips for getting that seal out. Its seems to be cooked right in there. Anything I can use, or do I just have to pic it out in pieces.
Thanks
Thanks
