Ok, so i just had to rebuild my 2007 RMZ 250(Cracked case).
I put in a new piston and rings, all new gaskets, new oil seals, new oil filter...The bike started second kick and seems to idle fine, its just when i go to rev it it shuts off. I re did the timing and it is set perfectly, now i can rev it alittle but it stills seems like it wants to shut off, and has alittle bit of a back fire every now and then, does anyone have any ideas what it could be? Thank you!
Rebuilt my rmz250, now some questions.
Started by
racer29
, May 18 2012 11:04 AM
4 replies to this topic
Posted 18 May 2012 - 12:21 PM
carb not jetted right is back firing or an air leak and sounds to me it only idling might be a jet clogged.
or hot start cable?
or hot start cable?
Posted 18 May 2012 - 05:36 PM
ohh i just cleaned out all the jets tonight, found some dirt in the quickshot though. I will be testing it on the bike tomorrow morning though...what could be wrong with the hot start cable?
Posted 19 May 2012 - 11:52 AM
if it was stuck slightly on it can make the bike run lean (back fire/pop) and have you ever held your hot start while the bike is running hot? usually will kill the engine
Edited by ontherev164, 19 May 2012 - 11:52 AM.
Posted 19 May 2012 - 11:55 AM
ohh no i havent even rode the bike yet actually. I bought it off someone for cheap because the case was cracked and the guy didnt have the time or money to fix it so thats what i have been doing, its the first time ive had the bike running actually haha...but i cleaned the carb out and now i have a new plug as well just in case, so im going to go throw that on and see what happens from there i guess. i will give an update in a few. Thanks for your help!
