I have size 11 feet, the stock shifter is too short for my taste. After reading the treads about that problem, i ordered a 05-07 Sunline shifter (longer that stock) had to grind a notch to clear a case bolt but it worked fine. 2 years later my Sunline shows enough wear at the tip , time to change it.
Hammerhead (+10mm) seems to be the best solution, it's just so expansive
another Sunline is unavailable (in Canada) right now, and i didnt want to grind a notch again...
Will a stock 05-07 shifter will fit without any grinding? I like the quality of OEM parts
thanks!
