Another Fuel In Oil Topic 2012 Crf250r
Posted 14 May 2012 - 07:55 AM
Posted 14 May 2012 - 10:11 AM
My gut says it is the injector and the fuel system remaining in constant pressure, but I also thought changing to a 2011/2012 injector was solving the issue for the 2010 guys. Well if you have a 2012 that may not be the case. At this point I am in the same boat as you, wondering what I need to fix/replace to get this thing to work. no help to you, but you arent the only one actively seeking a solution. Let me know what you hear from honda.
Edited by gaines1016, 14 May 2012 - 02:01 PM.
Posted 14 May 2012 - 12:21 PM
Posted 14 May 2012 - 01:09 PM
Posted 14 May 2012 - 02:09 PM
Posted 14 May 2012 - 02:25 PM
crf250rrider, on 14 May 2012 - 02:09 PM, said:
I have hit a false neutral one time before a double. I didn't give it a real firm shift though. Other than that I haven't had a problem. I got a call from my local dealer who talked to Honda for me. He said Honda told him that the minimum rpm needed to burn all the gas that is getting sent to the cylinder on a cold start is 1700 rpm. They also said to leave the high idle knob out until the bike is toasty warm and DO NOT touch the throttle when it is cold or fuel is just washing the cylinder. He also said if that doesn't fix it the fuel pressure would need to be checked along with the sensors. I think I'm going to invest in some die electric and do all the connection just to be on the safe side. I laughed when I heard him say Honda has had lots of calls about fuel in the oil
Posted 14 May 2012 - 03:30 PM
Posted 15 May 2012 - 04:09 AM
Posted 15 May 2012 - 12:31 PM
Posted 15 May 2012 - 04:22 PM
oil changes every 2 hours manual states oil changed every 2.5 hours any way. Honda knows , I called them it was like taking to a lawyer. No warranty. Let it warm up before riding it too. 8 hours on mine notcied the gas smell right away then pulled the dip stick out of my 06 and smelled it no fuel smell.
Honda knows of the problem and will basically laugh in your face!.
I read another thread on here and some guy was changing his oil every 15 years , I mean come on read your manual. Just stupid.
Posted 17 May 2012 - 01:15 PM
Why are you asking about false neutrals?
I have had quite a few recently... but no fuel smell (as far as I can tell), and no oil rising...
I also checked valve clearance just to make sure. the machine has 70 hours on it and they didn't budge... valves are fine!
I did get a back starting of the engine though last week and when the kickstart went back it broke the stopper in the case. Honda said it was caused by kickstarting it with the throttle open (which I didn't do). now that the problem is fixed I am trying to figure out what caused it so it won't happen again...
Do you think the two are connected? and what does the transmission has to do with it?
Posted 17 May 2012 - 01:45 PM
I have been hitting a false neurtral every now and then when i shift between 3rd and 4th. Those are the only 2 gears I really use though. It seems to happen when I try to do a really fast shift. I will click up and then its like somebody hit the front brake but then the bike goes into gear.
Posted 19 May 2012 - 03:36 AM
Posted 19 May 2012 - 05:14 AM
rayztruckz307, on 19 May 2012 - 03:36 AM, said:
The hardest part about it is remembering to do it.
