2011 YZ450F Preload adjuster
13 replies to this topic
  • JamesYZF
Posted May 13, 2012 - 05:36 PM
So my preload adjuster ring needs to be cut off and need to get a new one on my rear shock. But for the life of me, I can't find any online to see what the cost of it is or order one up. I tried looking on Yamaha's online parts catalog, and the closest thing I can come across is a "Seat, Spring upper", part # is 33D-22213-00.
The diagram can be found @ http://www.motorcycl...2011&fveh=51694 , and looks to be #7 from what the diagram says.
Is that the right part I'm looking for? I wanted the experts opinion on this before I go through with the purchase.
Posted May 13, 2012 - 07:48 PM
The adjuster ring is 33D-22213-00-00, and the lock ring is 33D-22234-00-00.
  • Monk
Posted May 13, 2012 - 08:01 PM
How about an X-trig instead of the ring? Its a little more expensive but its the cats meow!
Heres a link for MXAs test of it....
http://motocrossacti...DJUST-7346.aspx
  • JamesYZF
Posted May 13, 2012 - 08:03 PM
Thank you very much for your time. I very much appreciate it.
  • JamesYZF
Posted May 13, 2012 - 08:07 PM
That would be much easier to adjust the sag for sure. But, a bit more than I am willing to spend atm. Thanks for your recommendation.
  • Monk
Posted May 13, 2012 - 08:15 PM
My experts opinion is go with the X-trig.....whats going to stop it from happening again? What about downtime?
How often are you adjusting your preload to get to a point where you have to replace it.....just sayin!
  • phiderman
Posted May 13, 2012 - 09:08 PM
if the one on your bike is the same one on my 2010 i would get the rings from factory connection. they sell a billet set and are much more durable and less likely to destroy the threads on your shock. thats what i bought after mine seized and damaged my threads. no problems since.
  • rdefonce
Posted May 16, 2012 - 08:49 AM
Same here, siezed and stupid me I kept turning it. Ruined some threads.
Now I need spring compressor if I ever have to replace spring.:-o
I put on one from a Honda, works perfect and made from much better material (it's steel, not crappy soft aluminum.)
  • rdefonce
Posted May 16, 2012 - 08:58 AM
specifically, it's for '02 thru '08 CRF450R, and fit's my YZ450F perfectly.
  • delmas
Posted May 16, 2012 - 04:52 PM
get a 2007 crf450 honda set of pre load rings and you won't the problem any more
  • TahitianRed
Posted March 23, 2013 - 08:55 PM
Put an X-Trig on my 2008 YZ450F and after bolting things back together I noticed the airbox partially blocked the hex head. Maybe it's time to add some air holes to right side of the box. LOL
Anyone else running an X-Trig pre load ring on their 2008 or 2009 YZ450F?
Posted March 24, 2013 - 08:24 AM
I have on on my '06, and yes, the air box does interfere with it a bit, but it's still usable with either a nut driver or a tee handle.
  • TahitianRed
Posted March 24, 2013 - 09:31 PM
Yep the 1/4" drive 8mm deep socket and extension is definitely out. Tee handle was my next option, but woould have liked to use the power drill on it. LOL
  • SAthump
Posted July 11, 2013 - 02:38 PM
Does anyone have an X-trig mounted on a 10+ ??
I have one but found I would need a spring compressor (which I do not own) so I left it off, It seemed it was going to have a minimum of 10mm preload as well.
Now I had one on my KTM and thought it was great.
