2005 WR250 carb issue
5 replies to this topic
  • pobenda
Posted 12 May 2012 - 01:30 PM
Here's the problem I'm having.  My friends bike been sitting at my house for a little over a year and it was not started.  He didn't put stabilfuel in it so the ethanol kind of jammed it up.  I cleaned the carb as best as I can and changed all the jets.  Now when I start the bike it only starts with the choke out and when I push the choke in the bike revs up and down and can't idle unless i hold the throttle a little and then dies.  Also the header becomes glowing red for running about a minute.  Any suggestions.
  • keenxxx
Posted 12 May 2012 - 01:58 PM
Clean the tank, petcock & the carb. " I cleaned the carb as best as I can" -  Have the carb dipped or ultrasonically cleaned, sounds like it is still gummed up.
  • antleo
Posted 12 May 2012 - 06:28 PM
the header glowing is normal
  • pobenda
Posted 18 May 2012 - 05:38 PM
Update.  I cleaned the carb and everything seems clean.  I changed all the jets and now I think somethings wrong with the hotstart.  When the bike is idleing it sounds like theres too much air coming in.  When I press the hot start nothing happens.  It's like the hot start is wide open.  I changed the hotstart cable and plunger and still the same.  Why would the bike sound like the hotstart is pressed and when I actually press it nothing happens?  Also the bike gets real hot.  Hotter than normal where the radiator hose is smoking.
  • keenxxx
Posted 18 May 2012 - 06:13 PM
Intake air leak.
  • pobenda
Posted 18 May 2012 - 06:22 PM
Inside the airbox?
