GoPro of my Second race to critique
Posted 10 May 2012 - 06:04 PM
I realize that its hard to tell my body positioning and stuff since the cameras above my helmet, but anything you guys can point out from this angle would be great. I know theres lots of room for improvement !
Posted 11 May 2012 - 10:17 AM
Posted 11 May 2012 - 12:34 PM
Posted 11 May 2012 - 01:01 PM
Looking good man! Like it was said, it seems like you let off a bit on the start straight, and lost your momentum in the rollers. Other than that, pretty good.
Posted 11 May 2012 - 02:27 PM
I'm guessing you can use some turning and rut practice (as we all could). With experience you will learn when to be more aggressive. A buddy once told me " go fast when you can go fast". Seems kind of self evident, but when I thought about it, I found there were lots of times when I could go faster than I was.
Good job on your 2nd race. Keep it up...
Posted 11 May 2012 - 03:05 PM
Yeah I gotta be more aggressive for sure, I can tell i'm still timid, which i'm sure confidence comes with seat time. I noticed I was losing positions by taking the outside corners and rolling those whoops/rollers, something I'll for sure work on next time i'm out. I appreciate the feedback!
And yeah poor guy at 1:06 lol, first lap is never a good place to go down, especally with 35 bikes lined up!
Posted 11 May 2012 - 03:22 PM
Posted 11 May 2012 - 06:47 PM
Posted 11 May 2012 - 06:55 PM
Eric_mx, on 11 May 2012 - 06:47 PM, said:
Posted 11 May 2012 - 08:47 PM
Kool. Just be careful when seat-bouncing stuff. I was just telling Tye of how I almost had a bad crash 2 weeks ago because I lost focus while seat bouncing. (my bike suddenly lost power cuz the piston was messed up, and that caught my attention)
Posted 12 May 2012 - 07:26 AM
08rider, on 11 May 2012 - 06:55 PM, said:
My sag is set at 100mm with static sag at 30mm... thats about the closest we can get it without messing up the static sag, I'm assuming this means the spring is probably one size too stiff, but its pretty close to optimal ! I've been fiddling with clickers because I bought the bike off a pro who's lighter than me but the suspension was super stiff still. I had to go 8 clicks soft on the shock rebound because i could barely move the seat down with my hand.
I'm gonna ride the bike like this for this season and next year do a complete suspension overhaul taylored for me.
kx910, on 11 May 2012 - 08:47 PM, said:
Thanks KX, yeah thats why im starting small so I can get comfortable with the whole idea and not go into a full endo!
Posted 14 May 2012 - 06:56 PM
And last have fun that is more important than everyrthing else
Posted 15 May 2012 - 06:06 PM
I'm having a blast out there and I agree thats the most important part, why else would we be doing this right? Especially when starting my racing career at age 25 haha.
Posted 15 May 2012 - 09:18 PM
Circle drill
Circle drill
Circle drill
Circle drill
Circle drill
Still...Looking good. I hope I do as well if I ever try to race.
Forget about seat bouncing... It is not going to improve your lap times...and there are more fundamental things to work on. In Gary Semics Volume 3 vids...he does not even cover seat bouncing till the 7th vid. That means you should not be doing it unless you have the previous techniques all solidly mastered. Do you want to go fast...and turn faster lap times...or look good off the jumps. I would recommend you worry about the factors that result in faster lap times...and better corner exit speed. With good cornering...your wont need to seat bounce anywhere on that track. Dont be one of those guys throwing vet whips and rolling the corners tall....
Edited by Blutarsky, 15 May 2012 - 09:28 PM.
Posted 15 May 2012 - 09:47 PM
On the seat bouncing issue, I think you are on the right track by starting small. I completely disagree with Blutarsky however. I do not think seat bouncing is a technique for a total beginner, but you seem to be hitting some of those bigger jumps comfortably so I do not see evidence that you are a total noob. Nor do I think seat bouncing gives you extra "style points" like he says. It is a very very valuable technique and something that you can use to make passes if others you are racing cannot seat bounce. There may be a jump or two on that track that can be seat bounced from the inside and will be massively faster than going all the way around the outside and hitting them standing up. I will say this though. Pick the jumps you seat bounce carefully. Seat bouncing is a technique that is used at relatively lower speed and usually on jumps right out of corners. Don't try to seat bounce something in the middle of a straight away. Good job so far practice those corners!
Posted 16 May 2012 - 04:03 PM
Blutarsky, on 15 May 2012 - 09:18 PM, said:
Circle drill
Circle drill
Circle drill
Circle drill
Circle drill
Wouldn't it be a good idea for him to learn how to seat-bounce? I didn't say that he should be throwing whips or anything, but seat bouncing will help him clear those jumps out of corners. That WILL help him get faster lap times.
Edited by kx910, 16 May 2012 - 04:04 PM.
Posted 16 May 2012 - 04:57 PM
Edited by j368, 16 May 2012 - 04:59 PM.
Posted 17 May 2012 - 08:05 AM
Thanks guys for the circle drill tips, I do have a couple of Gary Semics cornering technique videos and they have definitely been helpful, I'm gonna do the cone drill for sure because I coast wayyy to much into the corners. And I'll be sure to protect that inside line for my next race too. Oh and I'll also keep it pinned on the next start, would love to get a holeshot one day!
Posted 17 May 2012 - 07:05 PM
Just my opinion on the seat bounce thing...but here is my perspective. I do not jump that well yet.....But I am pretty good from the point in a corner where you get on the throttle, onward. This is from doing the circle drill (which is a corner EXIT drill). My right turn corner entries are OK. My left turn corner entries are poor. Just the ability to exit corners well results in me riding faster over the course of a lap than many riders who can clear every jump with ease, manipulate the bike in the air...even seat bounce...but do not corner well.
When you come out of corners faster...the speed you hit the jumps at totally change. The whole track changes. Worrying about clearing jumps when you are hitting them slow because of cornering technique is treating the symptoms...not the causes. There is a reason Gary does not talk about seat bouncing till the 7th disc in Volume 3. It is an advanced technique, which NEEDS to be applied rarely (especially in outdoor MX) if you have all the other techniques down. It is also less forgiving of mistakes. Jumping is what everyone wants to do. Everyone wants to be able to clear every jump on the track. But few really ever put the stopwatch on themselves and others...and see where they losing the most time. Not clearing some of those jumps may not be costing you nearly as much time as you think.
As a beginner...I do feel seat bouncing should be learned...after you have learned the more fundamental techniques 1st. In fact...I think that learning to corner properly should be done before you really start jumping. Of course this is unrealistic as most riders do not have a large bit of property where they can create natural terrain tracks with no jumps....and a separate jump area.
Finally...you can always jump sitting down to get a little more boost...without incorporating full aggressive (and riskier) seat bounce technique where you shift weight way back to LOAD the rear spring to the max...then try to balance that energy with throttle. Just hitting a jump sitting down (again...safest just out of a corner) will give you quite a bit more rebound since you take your body absorption out of the equation. If your suspension is balanced, and you sit in the central body position, this intermediate step can get you safely over some jumps you can not clear standing up. It is also good to master before you start seat bouncing. A couple of those jumps coming out of corners are really not that close to the corner...and they are pretty large. Try to seat bounce those...you may end up in the hospital. Work in your cornering speed.
Edited by Blutarsky, 17 May 2012 - 07:48 PM.
Posted 17 May 2012 - 08:19 PM
Yeah, I know that cornering is the most important thing, but as a beginner (me), I think it's good to first get well rounded, then work out the rough edges. Especially cornering. I am getting much better at jumping, which will help me be faster and more confident in cornering, and vice versa. But I figure that at the point that I'm at, I need to work on both equally as much (cornering a little more). And when I'm able to jump with no problems at all, I will be able to focus mainly on my cornering speed. I mean, what's the point of being able to corner fast if you get scared when you come up to a jump? There wouldn't be any point. I just think it's good to be well rounded and comfortable in all areas of racing before you start focusing on just one thing.
Edited by kx910, 17 May 2012 - 08:20 PM.
