Exhaust pop on decel with FMF powercore4 slip on
3 replies to this topic
  • pschiess
Posted May 09, 2012 - 08:15 AM
The bike is a 2007 WR450F and is stock other than the usual free mods and jetted for the stock pipe. Once I put the FMF Power Core 4 on it I get the occasional POP when chopping the throttle. I have an adjustble fuel screw. Should I adjust it in our out to try to eliminate the decel pop? If so how much. It does not happen all of the time just enough to be annoying.
  • The Hopper Show
Posted May 09, 2012 - 09:40 AM
out
  • Pooley
Posted May 09, 2012 - 10:43 AM
A little popping on decel isn't bad, as long as it isn't excessive. Turn your fuel screw out roughly 1/4 turn at a time to richen the mix and eliminate popping. If you stall off-idle, or the hot-start is required too much (where it wasn't before) to restart, you would need to go back a tad leaner (in).
  • pschiess
Posted May 09, 2012 - 10:45 AM
Thanks. That is exactly what i was thinking. I appreciate the help. :banghead:
