1987 yam xt 350 carb to intake boot
13 replies to this topic
  • weemo1rush
Posted 08 May 2012 - 10:48 AM
Man o man why did i start.
Decided to give my carb a much need overhaul
While removing the bugger I managed to split both intake boots on the cylinder head.... cant get them for love nor money..... I think Im going to have to go do the fabrication of ali pipe work,welded on ali the collars and use silcone hose to join to the carb......
I shall never learn....
  • XTBuck
Posted 08 May 2012 - 06:00 PM
I got a set about two years ago through a local yamaha dealer here in the United States.. part #s 55v-13586-01-00 and 42U-12596-01-00.  I reckon its different in the UK.  Ive been meaning to hunt down some aftermarket replacements as I plan to build another xt350 engine soon.  I'm sure they are out there in aftermarket form but most likely without the little rubber piece that keeps the clamp from spinning when tightening them down.  I'll definately post and let you xt350 guys know if I find some.
  • stratosXT350
Posted 10 May 2012 - 02:06 PM
Im looking for a set of these as well.....Posted Image
  • kwakbiker
Posted 12 May 2012 - 02:16 PM
Was looking at XT600 ones, look sooo similar but have different part numbers on bike bandit.com
  • XTBuck
Posted 13 May 2012 - 07:38 AM
Unfortunately I'm pretty sure the spacing between the bolt holes is larger on the xt600.  When I get back to the shop tomorrow I'll try and get a measurement of both an xt600 and xt350 head to make absolutely sure. I think the xt600 carbs have bigger venturis and therefore bigger holes in the manifolds also though.  A good many older Polaris ATVs use manifolds that are similar but again the problem is with the smaller hole size of the manifold even if we can find some that bolt up.
  • kwakbiker
Posted 13 May 2012 - 07:57 AM
Yea tried some honda cb250 ones, bigger one end and the mount holes a few mm too wide
  • pd350
Posted 13 May 2012 - 12:09 PM
Maybe a rat tail file would make those mm disappear ...
  • kwakbiker
Posted 13 May 2012 - 01:47 PM
it would but then its the hassle of getting the carb end padded out for the larger bore, ways and mean tho lol
  • suzukisam967m
Posted 15 May 2012 - 04:14 PM
is there a difference in 87 and 93? i just ordered them for my 93 from power sports plus.. 45 bucks a piece.. or is it just that you are in the UK?
  • kwakbiker
Posted 16 May 2012 - 10:22 AM
As far as I know theres no difference if your stateside, in the UK the XT got restricted due to emmisions regs in the 90's but I think its only a small flap in the carb boot, you didnt have that problem so it should only be the full fat boots for all years in the USA
  • stratosXT350
Posted 17 May 2012 - 07:03 AM
suzukisam967m - Thanks for the heads up!!! I just went online to powersportsplus.com and ordered a set of carb joint for a great price! Also found and online coupon code for a further discount!! Cheers!!!!
  • suzukisam967m
Posted 17 May 2012 - 02:02 PM
...whats the coupon! I just ordered mine with no coupon!....crap
  • stratosXT350
Posted 17 May 2012 - 05:25 PM
meetsister
  • kwakbiker
Posted 14 June 2012 - 07:18 AM
Just a bouce for this thread. Bloke over on advrider(sure at least some of you must be on the site) has posted this stuff to use as a replacement
http://www.pratley.c...Y_Adhesives.htm
He says to scroll down to the car wondafix bit as thats the stuff he uses, cheap enough to give it a go....I will be
