rm250 03 for wood riding
14 replies to this topic
  • amitx
Posted 07 May 2012 - 07:42 AM
i wonder if i need to change the mid valve stack, what i got now is (stock, i think):
nut
2x 13.1x0.3
1x 22x0.4
1x 14x0.1
1x 12x0.1
2x 10x0.3
1x 16x0.1
1x 18x0.1
1x 20x0.1
1x 22x0.1
3x 24x0.1
valve
4x 23x0.1
1x 21x0.1
1x 15x0.1
1x 10x0.1
1x 18x0.1
1x 16x0.1
1x 14x0.1
4x 12x0.3
thanks.
  • Vietze
Posted 07 May 2012 - 10:16 AM
No, thats not stock
stock is
reb 23-0.11*5 13-0.11*1 20-0.11*1 18-0.15*1 16-0.15*1 14-0.15*1 12-0.15*1
10-0.30*3
MV 24-0.11*3 22-0.11*1 20-0.11*1 18-0.11*1 16-0.11*1 10-0.30*2 12-0.11*1 14-0.11*1 22-0.40*1
base 24-0.15*6 22-0.15*2 18-0.15*2 14-0.15*1 11-0.25*1
Edited by Vietze, 07 May 2012 - 10:17 AM.
  • amitx
Posted 07 May 2012 - 11:14 AM
Hi thanks for the info.
maybe in Europe is different from the US bike?
any way i talked just about the MV only, i didnt open the base Valve.
can it be that my stack worked fine or i missed up with the order??
i'm newbie with that and i see that MV is in the opposite from what i rote, from what direction should i write? from the valve -out side?
in the rebound i didnt find noting close, it looked like the nut was closed and never opened.
thanks again.
  • Vietze
Posted 07 May 2012 - 11:30 AM
My records are directly from technical touch in belgium.
I did a pair of 250 RM 2002 forks recently and this fork also has 23 OD faceshims on reb.
So maybe you mixed it up.
  • mog
Posted 07 May 2012 - 11:45 AM
He has the same mid as you state Flo but a different rebound
  • Vietze
Posted 08 May 2012 - 01:11 AM
Yes, a very crazy looking reb IMO.
What are your complaints amitx?
Would be nice to see your base too!
  • tribalbc
Posted 08 May 2012 - 08:57 AM
I left the mid alone on my 03 and changed the base with a suggested stack by Mog last year. I love them as I was just looking for a little more plushness on the initial stroke. I find they make a perfect woods fork for me, click in 6 or 7 clicks on compression and they're decent on the MX track.  But I also like a stiffer fork in the woods than most as I'm tall and an A racer.
If you're interested I'll find my specs for you.
  • amitx
Posted 08 May 2012 - 09:19 AM
i dont really remember how it worked, the rods of the MV broke and since then i didn't ride the bike (2-3 years).
since i opened it and fixed the rods i said why not to chance it for a wood riding.
i do know that my bike was a bike of TEAM F&S from Ohio(did they have a Team??).
i will take a look at the base valve too.
so what should i do? to reassemble it like it was??
yes i will appraise that, but i see that i have different rebound, so i need to dill with that too, now :banghead:
did you use the stock springs? i did ride a MX and i think the forks were ok, i do remember that the shock was too soft and bottomed easily if i missed the lending.
Thanks again.
Edited by amitx, 08 May 2012 - 09:25 AM.
  • amitx
Posted 26 May 2012 - 12:45 PM
In the end i didnt touch noting cause i dont really remember how things worked at the forks, so after i will ride it i will see what i want to change and will find out how.
From what i looked at the base valve it looks like stock 24s and few of 22 noting different like my rebound(dIdnt open it) but from what i could measure with caliper it looks like what Vietze said.
So if someone have some tips for that KYB i would be more then happy to find out about it,
thanks.
Amit.
Edited by amitx, 26 May 2012 - 12:49 PM.
  • Vietze
Posted 26 May 2012 - 03:41 PM
Firstly you have to remove the bladder from the cartridge.
.15 shims in the base arent the best idea, especially for a woods bike.
  • amitx
Posted 28 May 2012 - 01:20 PM
sorry on the dummy Q, what is bladder?? :cry:
thanks
  • Spocko
Posted 28 May 2012 - 08:12 PM
thanks
http://www.thumperta...bling-bladders/
  • amitx
Posted 29 May 2012 - 05:07 PM
Thanks Spocko but i dont think that i have this bladder in my forks, didnt see noting like that.
mine are different forks then the RMZ.
or some one just remove them before but i dont belive that it didnt look like that.
Thanks
  • amitx
Posted 08 June 2012 - 12:41 PM
ok after riding with that shims i can say that the compression are too hard at  small rocks and i think also hard feel overall.
now i also have a problem with the rebound, it's too fast also when fully close.
i put springs withe the needles, i think they may be the problem, i didnt find springs in the suspension when i open them but i have been told there were spring there, so is there really spring there? if yes from where can i get them?
i saw in RMX that there are springs, could they fit my KYB?
thanks
  • amitx
Posted 12 June 2012 - 05:18 PM
no one knows??
Helppppppp me  please :devil:
