426 clutch in a Wr400?
1 reply to this topic
  • R_Little
Posted May 07, 2012 - 06:53 AM
The 426 has a bigger clutch with one more plate.
Does anyone know if I can just replace the stock Wr400 clutch with a 426 clutch?
Is it a bolt in?
I presume the gears, and clutch shaft splines and length are the same on both trannys?
  • RasmusDK
Posted May 07, 2012 - 02:55 PM
I read once that it can be done, BUT you will pretty much need a 426 donor engine. The basket is bigger in diameter etc...
