08 rm85 no low end to mid range power
3 replies to this topic
  • docholaday67
Posted 06 May 2012 - 07:20 PM
the bike runs fine as long as you are running it wide open throttle. when you try to run 1/4 to 1/2 throttle it dies then starts up and runs fine when
my son goes back to wide open throttle.
  • dtha70
Posted 07 May 2012 - 01:14 AM
sounds like a clogged pilot circuit. take out the pilot jet, and try to look through it, if you cant see daylight, then get a new one and give it a shot. if you can see through it, then it could just be really really lean on the pilot. did it just start doing this or has it done it all along?
  • moto man rm250
Posted 07 May 2012 - 06:20 AM
Try running a 45# pilot jet should clear it up and if you want more bottom end you need to change gearing I ran a 13 front and 48 rear on my sons 85 and it made a big difference compared to the stock 14-47 sprockets.
  • docholaday67
Posted 09 May 2012 - 06:51 PM
thanks for the replies.  the pilot jet was plugged
