setting up my bike, what do these numbers mean?
Posted 06 May 2012 - 04:06 PM
I took some numbers for the sag, here they are.
R1*bike on stand =24 3/4in = 628.65mm
R3*bike on ground, no rider = 24 5/8in = 625.48mm
R2*bike on ground, with rider = 21 3/4in = 552.45mm
Note: I was standing on the bike instead of sitting, is there a big difference?
Note: I am 5' 9" tall and about 160lbs
So, from those numbers i understand you do R2-R1=Race Sag and R3-R1=Static Sag correct? So with these numbers do i need a new spring what do i need to do to make it more set up to me. Oil weight, springs, etc.
Also i measured my forks to.
F1*Bike on stand = 35 1/8in = 892.17mm
F2*Bike on ground, with rider = 34 1/4in = 869.95mm
F3*Bike on ground, no rider = 33 1/4in = 844.55mm
I do not know what to do with the fork numbers to figure out what i need?
So if anyone can help me set my bike up for me that would be great. I ride in so-cal area, plaster city desert so hard pack, sand, and i also ride track.
Posted 06 May 2012 - 04:18 PM
Posted 06 May 2012 - 04:51 PM
it should be
F3*bike on ground, no rider = 869.95mm
F2*bike on ground, with rider = 844.55mm.
i will re do the front forks tomorrow to double check, are you saying the rear numbers are wrong too?
i read somewhere you can messure them standing if you wanted to? whats better setting riding position or standing riding position?
Edited by peezy, 06 May 2012 - 04:52 PM.
Posted 06 May 2012 - 04:57 PM
Posted 06 May 2012 - 05:05 PM
Edited by peezy, 06 May 2012 - 05:07 PM.
Posted 06 May 2012 - 05:11 PM
Posted 06 May 2012 - 05:15 PM
Posted 07 May 2012 - 04:46 PM
peezy, on 06 May 2012 - 04:51 PM, said:
it should be
Posted 17 May 2012 - 12:31 PM
Also if i don't want to spend so much money on re-doing my whole suspension, could i just re charge the rear shock, and change the oil in the forks?
Thanks for the help. I will post the numbers when i get home and adjust the race sag.
Posted 17 May 2012 - 07:13 PM
a=bike on stand
b=bike off stand, with rider
c=bike off stand, no rider
a= 635mm
b= 536.70mm
c= 622.3
so i figured my race sag is 98.3 and my static i am not to sure of yet. i think i got 12 but not sure.
My friend thinks my shock is blown, could it just might need a new spring? or maybe should i try re-charge it and go from there?
Posted 18 May 2012 - 04:57 AM
Posted 18 May 2012 - 06:59 AM
Posted 19 May 2012 - 09:42 AM
Posted 19 May 2012 - 11:00 AM
Posted 19 May 2012 - 11:27 AM
Posted 19 May 2012 - 01:10 PM
Edited by YHGEORGE, 19 May 2012 - 01:10 PM.
Posted 20 May 2012 - 09:26 AM
Posted 20 May 2012 - 10:36 AM
Finding someone who can show you may be your biggest hurdle. If you were local to here, I'd be glad to show you and I have all the normal rebuild parts in stock for 98% of the components out there made in the last two decades. I'd suggest not relying on your neighbor but someone who does it for a living.
