Front brake issue
1 reply to this topic
  • the big kx
Posted 06 May 2012 - 01:42 PM
Hey folks,
Was riding this morning when I clipped a tree (I had non-wraparound hand guards installed which I now realize is sincerely inferior to true bark busters) and the guard bent back and did SOMETHING (operative word, not mechanically inclined) to the front brake.
Since then the brake will sometimes apply pressure, but only for a short while before it's touching the grip and doing nothing. There doesn't appear to be any fluid leaking from the line.
I am aware this could be a number of things, but does anyone know how I could fix this? Or what is wrong? Perhaps something to do with the caliper? Again, this is probably something rudimentary but I haven't a clue.
Thanks for the help
  • Pr1malR8gw
Posted 06 May 2012 - 09:18 PM
To give you an understanding of how brakes work [which will explain whats going on]. Brakes are opperated in most cases which yours is by hydralic force. A pump being your mastercylinder[from now one abbreviated MC] attached to a lever is used to push oil from the MC down a hose to the calliper which in turn pushes against pots in the calliper. These pots also push the brake pads and calliper to squese the rotor creating friction which slows the rotation of the wheel. Now.. if you don't know  liquid cannot be compressed [it can but thats requires so much force it's not in this equasion]. So with this in mind once the pads hit a point where the liquid [brake fluid] can no longer move the hydralic action stops and in doing so if more pressure is applied at the MC then what the caliper/pots can expend the access pressure must go somewhere.. Either A. the hose becomes comprimized or the pump it self blows it's seals. brake systems are designed to be stronger then what our hands can generaly generate but it can not withstand the amount of force that is had in your crash. Most of the time the pump fails in that type of thing but if it's an older bike with the stock rubber hose it might possibly have blown. Even though you may not see fluid leaking does not mean the hose is still good. It can blow but not leak. Inside those rubber hoses is nylon string that prevent expansion but if they brake the hose can expand easier then the caliper's pots.
In an accident like that and your discription. I would replace the hose and have the MC rebuilt with new seals and piston.
