Can the shock spring be removed on TTR 50
1 reply to this topic
  • randybuckman
Posted 05 May 2012 - 07:57 PM
Can the stock shock spring be removed on the ttr 50? If so could someone please tell me how it is done. I have found directions for the CRF shock, however they are not the same. There is no nut under the bottom stop.
  • Smacaroni
Posted 07 May 2012 - 06:51 AM
You probably need to compress the spring and then slide a retaining plate from between the "skinny end" eye and spring.
