Picking up a 2011 yz450 Monday for hard scrambles and enduros. I want to swap over my trail tech vector from my RMX. I'll need to order a new wheel sensor but the temp sensor will work fine. The RMX has a lighting coil so I spliced into the headlights power so it's not running off the watch battery in the computer the entire time. I know there's no lighting coil on the yz but since it's fuel injection is there any type of 12v system I can tap into for power to the trail tech without hurting anything?
Trail tech install on 2011 yz450 power wire?
Started by
upnorthbacon
, May 05 2012 03:37 AM
3 replies to this topic
Posted 11 May 2012 - 09:56 PM
For anyone interested, the red wire on the tuner port is the positive and is roughly 14volts and worked great. I'm also going to be wiring in a fan and toggle switch to run a fan in the single track if needed as well.
Posted 12 May 2012 - 11:51 AM
Check out Baja Designs. They have a lower harness for this purpose that is plug and play and comes with a handle bar switch for the light. It's about $15.
Posted 12 May 2012 - 07:55 PM
I just noticed it after wiring mine up! Oh well, maybe I'll have to buy some lights and plate it now too!
