How do you properly warm up a 2 stroke? how do you guys do it? whats your opinion?
Posted 04 May 2012 - 12:54 PM
Posted 04 May 2012 - 01:01 PM
when you feel the exhaust and its warm its warmed up.
DONT REV IT OUT ON THE WARM UP!!
and always let it warm up.
Posted 04 May 2012 - 01:49 PM
Posted 04 May 2012 - 01:51 PM
Posted 04 May 2012 - 01:55 PM
the piston will expand when it warms up and snug up the tolerance between the piston and jug. if you rap on it too hard too often you take a chance of cold seizing the motor.
i do love seeing idiots just rap the piss out of their bikes immediately upon startup. funny thing is you rarely see them often. wonder why?
Posted 04 May 2012 - 01:58 PM
txkawboy, on 04 May 2012 - 01:51 PM, said:
Edited by kellett25, 04 May 2012 - 01:59 PM.
Posted 04 May 2012 - 02:01 PM
Posted 04 May 2012 - 04:29 PM
OR as suggested, do doughnuts in the parking lot to warm it up....JK
Posted 04 May 2012 - 05:18 PM
Posted 04 May 2012 - 05:40 PM
The single best thing I can tell you about letting it warm up, is feeling the fat exhaust pipe (expansion chamber) after it's been running for a couple of minutes. My service manual tells me to let my bike run for roughly 3 minutes when doing gear oil changes, so that it is "fully" warmed up. This way the oil pours out much smoother and faster, all in one motion vs. if it was cold.
When it's cold out you need to give it a little longer, and when it's warm out, it won't take quite as long. Very simple. Like I said, best way to physically tell is touching the pipe. Try not to keep the choke on too long, unless it's actually pretty cold out. All the choke really is in an enrichenor circuit, that temporarily makes your pilot jet more rich (more fuel/oil) which is required for the actual starting. Once it has been started, it really is not needed. I leave it on until the bike will idle just fine without it, which is typically immediately for me unless it's really cold, like stated.
I typically will start the bike cold 2nd kick, and I try to let it idle on it's own for at least about 30 seconds, to get the oil fully circulated. After 30 seconds I will begin giving her some little love revs, ya know just little blips of the throttle. Once the pipe is hot after 2-3 minutes she is warm enough now to give her some nice solid revs, and then I will take it down a straight away and take it through the gears to get the gear box nice and warmed up, and after that she's fully ready to go.
I mean what kind of fool revs a motor way up on a cold start anyway?? It's not like letting it idle is going to "flood it out" after a couple of minutes when it IS finally warm, THEN you can hit the over-rev and clean her out, or take it down a straight away like I do. The only difference between us and them, is that we over-rev it when the motor is sufficiently lubricated AND they DON'T.
Also be sure your premix ratio is around 32:1. Mixing too little oil with the gas or having lean jetting is way worse than not warming it up, because then it is not getting near enough oil per revolution ALL THE TIME, which leads to the "Ka-Boom" we all know and love
Posted 04 May 2012 - 07:15 PM
Posted 04 May 2012 - 08:21 PM
you need to give the cylinder bore time to expand and the rings to expand to the size of the bore, let it warm itself up, give it a blip of the throttle if it hicups its not quite there yet, if response is normal your ready to go. hope this helps
Posted 04 May 2012 - 09:38 PM
LET IT IDLE. Blips are more than fine after initial start up, once it's running on it's own without the choke but I mean very small blips. That's why they're called "blips". Real fast and short.
Posted 04 May 2012 - 10:34 PM
I start it up and let it idle for 20 seconds or so, just until you can give it a little blip without the bike bogging or working hard. You know what I mean if you have road a 2 stroke and tried to rev it right after starting. Then after that a little blip every 10-15 seconds for about 30-45 seconds. Then put her in 1st and roll around for a while like your about to do something sick, then when she's cleared out you can hit the band.
If it's cold I let it idle for 3-4 minutes with no revving and usually 30 seconds with the choke. It can get damn cold up here in the great white north that sometimes you can't even feel the warming up after 4 minutes of idling.
Posted 04 May 2012 - 11:13 PM
Posted 04 May 2012 - 11:25 PM
Posted 04 May 2012 - 11:26 PM
this is how you warm up a 2 stroke
Edited by noysy1, 04 May 2012 - 11:27 PM.
Posted 04 May 2012 - 11:34 PM
Here we see the excelent socal bro technique although he forgot his Srh hat. He was clearing it out really good there with the 5 second wide open revs. Now that's a bike I wanna buy well cared for....LOLOL.
