Possible to convert 650 to run on ethanol?
Posted 04 May 2012 - 12:33 PM
Anyone ever done this? Anyone have any idea if it can be done?
Posted 04 May 2012 - 03:00 PM
Here is a link with the basic information.
http://running_on_al...d.com/id32.html
Edited by uspsamaster, 04 May 2012 - 03:04 PM.
Posted 04 May 2012 - 11:34 PM
Fuel is a patheticly cheap commodity. You do realise bottled water is more expensive? a chocolate bar and a bottle of water would substitute for what 80km of highway riding?
either 1) cut back on the silly things that become 'loose change items'
or 2) earn slightly more and go nuts.
The rate of exchange on fuel is still very low for what you get out of it. I can't fathom how people can believe it's a great expense, even on a minimum wage you can afford to burn as much of it as you want if you get your priorities right. Other things in life - which we never question the cost of - are so much more expensive and would be better served putting focus there if you want to be more financially efficient
Edited by qwerty1234, 04 May 2012 - 11:35 PM.
Posted 05 May 2012 - 05:09 AM
Posted 05 May 2012 - 08:36 AM
Posted 05 May 2012 - 08:37 AM
Posted 05 May 2012 - 02:25 PM
It's not about the cost of fuel as it sits now. Money isn't really a concern for me. 2 years ago I was unemployed and BARELY scraping by. IE actually took seat cushions up to fine enough money for diapers at one point. So I do indeed know what it's like to not have enough for frivolous fuel spending. But I digress, as this isn't the point of my post.
As I said, I'm not worried about the cost of fuel right now. What I'm worried about is the cost of fuel in an emergency. When supplies for whatever reason dry up. When something beyond our imagination (in our present cushy world), happens and we are forced to live without the conveniences we now enjoy. I'm no a doomsdayist (that a word?), but I do think being prepared for circumstances beyond our control is one thing that IS in our control.
On that note, this is about what if. I'd like to find what sorts of problems I'd face in the conversion. What all I'd have to change out to use with both gas and ethanol, and what would have to be replaced completely.
What if....
Posted 05 May 2012 - 05:03 PM
Yeah, everything I've read says there will be a loss of power and fuel economy. Simple fact is that ethanol does not have the energy per volume that gasoline has. That, really is a non issue for me though. The point of my looking into this is that imho, SOME power is better than NO power. I'd like to be able to run the bike on straight ethanol that I can make in my garage. My thought was that I could switch out all the rubber components to components made with material able to withstand ethanol, put a high compression piston/cam in, and re jet to to optimum output.
Keep in mind, my intention is not to do this to my much loved everyday DR650. I plan to do it to an older bike, work out the kinks, and have a conversion plan for the good bike if I ever need it.
Posted 05 May 2012 - 05:49 PM
Swap out all rubber components.
High compression piston/cam.
Rejet.
I'm wondering If I'd need to put a sleeve in the piston that would withstand corrosion better? That would go for the other metal parts too I spose... Ethanol can be pretty corrosive from what I understand. Anyone know anything about that aspect of it?
Edited by mattheritage, 05 May 2012 - 05:58 PM.
Posted 05 May 2012 - 05:53 PM
Posted 06 May 2012 - 06:20 AM
Posted 06 May 2012 - 09:47 PM
Seriously this is tin foil hat stuff...
Posted 07 May 2012 - 02:55 AM
(... play something ... sad.)
Posted 08 May 2012 - 08:50 AM
Jhawins, on 05 May 2012 - 08:37 AM, said:
Posted 09 May 2012 - 07:44 AM
Posted 10 May 2012 - 04:34 AM
uspsamaster, on 08 May 2012 - 08:50 AM, said:
My plan is to get all the information I can, find E100 friendly parts, etc, and then convert an older bike. Get it dialed in, and then decied if I want to convert my bike, or just have parts on hand to do a conversion if I ever need to. I would like to convert to EFI, and then have the option of switching back and forth. If that could be done it would be the best way to go I'd think.
I'm not really worried about the nay sayers. You have to expect that when you ask a how to question on a site like this that a good portion of the responders are going to tell you how dumb your idea is instead of simply offering relevant information. Thanks for the words of encouragement though.
Posted 10 May 2012 - 06:17 AM
rcthirty, on 09 May 2012 - 07:44 AM, said:
From your sig it looks like you've done the Ecotrons EFI kit? I'm looking at doing EFI. How was it to install? Run into any problems? Hows it run after installation? Happy with it, worth the money and all that?
Posted 11 May 2012 - 03:46 AM
mattheritage, on 10 May 2012 - 06:17 AM, said:
Bottom line is it's close but we still need tweaking. I'm happy with it and I think it's worth it, but mine is for street and fuel milage is a big concern for me. A carb would certainly be easier to fix if you broke down in the woods.
Posted 15 May 2012 - 09:09 PM
Posted 04 July 2012 - 11:22 PM
I'm planning on E85 for my recently acquired '86 XL600R.
Who's done this already? What's the news?
I'm just sharing my plan, and what I've learned so far...any informed or experienced advice anyone can offer would be great.
I'm planning:
1. Advancing ignition timing - 3deg retarded of detonation (estimating 18 deg BTDC)
2. Anodizing the carb bodies, Type I, Chromic Acid (though many hot rod and drag racing forums say the corrosion is a myth - unless there's a lot of moisture present)
3. Re-Jet, all circuits - possibly swap to a Mikuni TM-38 - float needle with neoprene tip, floats made of HDPE. Viton fuel line.
4. Fuel capacity Increase - Clarke 4.2 gal
5. Engine - 12:1 static compression ratio (piston, rings, wrist pin)
6. Metal screen fuel filter
these are just extra steps to complete the package - not E85 necessity
7. 'XRs Only' exhaust (headers, collector, muffler)
8. Balanced Crank, knife rod
What I'm debating (please chime in if you think it's needed for alcohol):
Cam
Porting
titanium valve springs
What I've read is that many people really hate ethanol. It's the devil. It corrodes or dissolves everything, your power and mileage drop 30%, and it starves people all over the world and poisons every fish on the planet.
Of course it does.
What I've ALSO read is that while it consumes 30% more fuel, you can gain back that mileage if you take steps to make your engine E85 compatible with compression and timing. If you have more power with more fuel, you use less wrist to get there, and, subsequently, more smiling with more wrist...the guys on the drag racing forums all accept the power gains as very real, and the occasional genius / mad scientist on the forms points out that the corrosion is from water.
Corroding aluminum - it's from water...and all the hot rod guys say this is very rare, even on their streetable daily drivers.
Dissolving plastic - yes...unless you know there are many, many kinds of plastic, and some of them are fine (HDPE, Teflon, Tefzel, Polypropylene)
Power drop - not true. You gain 20% with timing and compression - not possible with pump gas!
Mileage drop - true. You need to use more fuel. I've read 30%
Starves people - Only if you make it out of food...like pianos kill elephants if you make them out of ivory. Look up what petroleum does, while you're at it.
Poisons fish - Yes, if you make it out of corn, which you really don't have to (and shouldn't) Agribusiness uses a lot of Nitrogen fertilizer on mono-crop farms, which washes into the gulf and grows a dead zone of fish.
That's what I've learned so far. I hope this helps. When I get things under way, I'll be sure to share progress and results.
