I have a 04 315R and want to replace my sprockets but I'm having difficulty finding aftermarket sprockets.
I had similar problems finding a rear sprocket for an old XR but found a 02 YZ that uses the same sprocket. rocket
Any suggestions, crossreference to other bikes, or links would help.
Thanks
315R Aftermarket Sprockets
Started by
chuck4788
, May 04 2012 11:36 AM
5 replies to this topic
Posted 04 May 2012 - 12:56 PM
Have you tried lewisport?
Other than that you might check other trials bikes or maybe a cr125 of that era. When I rebuilt mine, there were a few small engine parts shared with cr125s and 250s... If that doesn't work you could try having one made, I know there is a place around here that does water jet cutting and they say they have a program for gears and sprockets. I've never asked about having a motorcycle sprocket cut though.
Posted 04 May 2012 - 11:14 PM
Thanks, I'll check the CR stuff..
I'll pull the both sprocket this weekend and measure them. The front sprocket looks like a XR200, and the rear uses 6 bolts in a 2 x 3 pattern.
Posted 05 May 2012 - 05:48 AM
Look here http://lewisportusa....eels_sprock.htm
your bikes has AJP hubs not the same as CR so sprockets wont interchange.
as for making them .....WHY? Just call Lewisport
