hey &%$#@!inalive in need of help......again!
2 replies to this topic
  • rmstrg
Posted 03 May 2012 - 06:10 PM
i finally got a rekluse and its amazing piece like you said now i have a new problem, put a new top end and cylinder in it and it runs 20 seconds and then dies. pretty sure its the tip over sensor and i cant figure out how to reset it. is there a way to bypass it?
  • dirtbikersa
Posted 04 May 2012 - 03:01 PM
there is a arrow on the tip over sensor, make sure it is facing upwards. You don't need to reset anything. I would not bypass it, just get it the correct way around.
  • funkinalive
Posted 05 May 2012 - 01:00 PM
you know, a simple PM would have been enough, but a whole new thread with blasphemy in my name works too :banghead:
As dirtbiker suggested, you just need to set it right and make sure its mounted correctly in the rubber boot, and in turn, the boot is correctly mounted on the frame. if everything looks good and the issue persists then you may have a sticking switch in the TOS. unfortunately i havent had these appart before, but ive heard they are rebuildable (need verification)
EDIT: as for a bypass, theoretically it is possible, but you would have to consult an electrician
Edited by funkinalive, 05 May 2012 - 01:02 PM.
