help resolving engine/carb problem
7 replies to this topic
  • antleo
Posted 03 May 2012 - 12:18 PM
So over the winter i cleaned up the bike cleaned the carb and adjusted the vavles. I am not sure but i think i messed something up. I didnt have the bog last year but this year its pretty bad and pops a bit. never did before i am taking off the carb again and checking that as well as the vavles. I think the timing might be off by a tooth or something can someone please give me a picture of their cams at tdc?
  • dgcars
Posted 04 May 2012 - 01:16 AM
You should have 12 pins between the punch marks.  I'd start by replacing your PJ first though.
  • antleo
Posted 04 May 2012 - 11:04 AM
what do you mean 12 pins?
  • antleo
Posted 04 May 2012 - 11:11 AM
i took a look at the pj and it still looks perfect all 9 holes are clear.i also looked at the leak jet and it looked good. i was thinking maybe tps? if it isnt maybe plug witch ill replace but i kinda was hoping i could wait till june soi can get my bike dyno jetted in ny as i am moving.
  • dgcars
Posted 04 May 2012 - 02:21 PM
Each link on the cam chain has 2 pins.  A good check is to count the number of pins between the punch marks on the cams.  You (YZ) should have 12.  Even though the PJ looks clean, i'd still replace it.
  • William1
Posted 05 May 2012 - 05:47 AM
Confirm the AP is squirting. A bog after a winter sitting with E85 can cause trouble with the AP.
  • antleo
Posted 08 May 2012 - 01:01 PM
i replaced the pj, the ap is squirting, and the timing is spot on. I haven't been able to try to start it or anything yet because of all this rain...I hate it.
  • antleo
Posted 09 May 2012 - 04:48 PM
all fixxed turns out that the neutral switch had some affect on it cause i tried removing it and it fixed it.
