2009 450 needs more power ?
Posted 03 May 2012 - 03:57 AM
Thanks
Posted 03 May 2012 - 04:04 AM
Posted 03 May 2012 - 05:38 AM
Posted 03 May 2012 - 01:48 PM
Thanks
Edited by racerx-936, 03 May 2012 - 01:50 PM.
Posted 03 May 2012 - 02:08 PM
racerx-936, on 03 May 2012 - 01:48 PM, said:
Thanks
So did you bore it out? Or do you mean like the A and B piston sizes? And I can almost guarantee that it isnt slow, the motor just doesnt have a hit, and that makes you think it is slow
Posted 03 May 2012 - 02:22 PM
Posted 03 May 2012 - 04:50 PM
Posted 03 May 2012 - 07:09 PM
Edited by Dasquriel, 03 May 2012 - 07:10 PM.
Posted 03 May 2012 - 07:59 PM
Posted 04 May 2012 - 01:35 AM
Posted 04 May 2012 - 04:43 AM
Edited by Ed2006CRF450R, 04 May 2012 - 04:44 AM.
Posted 04 May 2012 - 09:38 AM
Bigger as higher compression, or bigger as from 96mm to something bigger than 96mm?
And more power? More where, more bottom end? More top end with that bike with that pipe and a remap is tough to believe. Ive ridden an 09 with the yosh pipe and a remap (yosh) and it flat hauls ass. It is a little soft on the bottom though.
A higher compression piston should bring that to life though. But if you just wanted more bottom end, a Stage one with the stock piston is an option, but again, looking at remap. But Id try the cam by itself first.
The 50mm throttle body is part of the bottom end power issue. In 2010 they went to a 46 which is a pretty dramatic change.
Posted 04 May 2012 - 09:41 AM
Thanks
Posted 06 May 2012 - 01:33 AM
Do you know if the 46 work on an 09? I'm sure the map would need to be different. I have a tb insert but that just kind of convolutes the intake not optimal imo. I really like to run my bikes a gear n a half high and I'd like more chug. I think the 46 would help. She's not ready for a you comp piston yet there's just not enough hours to justify it.
Posted 06 May 2012 - 09:43 AM
englertracing, on 06 May 2012 - 01:33 AM, said:
That insert basically does the same thing. You just need to remap it. For low end power you need to raise the air velocity at lower RPM and that insert does that for you.
The 09's were a little rich off the bottom anyway, then you added the insert which would raise the velocity, but also reduce the MASS of air flowing in, so you'd need to lean it a little bit on the lower TP settings. Or add some timing in. With it rich, adding some timing would really make it bark off the bottom.
Honestly, I think you should probably call Eddie Sisneros and tell him what youve got. He's probably got a map. A map from a later bike with the smaller TB may work well for you too, but I'd call Eddie.
Posted 06 May 2012 - 10:48 PM
Posted 07 May 2012 - 04:24 PM
Edited by Ed2006CRF450R, 07 May 2012 - 04:25 PM.
