KX65 FORK OIL
3 replies to this topic
  • COAL RUN
Posted 02 May 2012 - 07:48 AM
Replacing the fork seals on an 08 KX 65 using 7WT oil  for 60+ lbs woods rider, wundering if setting the oil level at 125mm from the top (fork collapsed spring removed) would be the correct level?
  • Smacaroni
Posted 02 May 2012 - 10:24 AM
Seems a little high to me, it's much easier to add more than remove it after, I'd go for 5.5" or 140mm
  • shortyr6
Posted 04 May 2012 - 03:58 AM
I dont know what the manual says, but yes....forks collapsed and spring removed.
  • COAL RUN
Posted 11 May 2012 - 05:02 AM
I ended up going 130mm from the top per the "Team Green" site & it seem to be working pretty well so far with the 7wt oil.
