Shock bladder replacement
5 replies to this topic
  • supergee
Posted 01 May 2012 - 08:32 AM
Hi guys.
I'm in the middle on rebuilding a 1991 WR250Z shock and am in need of a new air bladder. Now the problem - The bladder measures 46mm x 113mm (ODxL) but I can't find an exact replacement online. The closest I can get is a YZ 250 bladder with dimensions 46mm x 103mm. Now my question - Will the shorter bladder make a difference? In theory I might just have to add a touch more oil.
Or do I really need to replace the shock because I can't find a $10 part?
Cheers.
Posted 01 May 2012 - 08:52 AM
The bladder will be large enough, but a more important question is whether the later one will fit onto/into the bladder cap properly and seal as it should.
  • Vietze
Posted 01 May 2012 - 09:16 AM
Your old bladder expanded to the seize you measured.
Its not the stock seize with 113 mm length.
The left one was in a shock a serviced. The right one is a new KYB Bladder 46x103.
Uploaded with ImageShack.us
The new one is 46mmx103mm
  • supergee
Posted 01 May 2012 - 09:36 PM
@Vietze - Thanks a lot. That was the info I was looking for!
@garyracer513 - I'll have to buy one and hope for the best. I'm pretty sure it will work after seeing that picture above. Thanks!
Posted 02 May 2012 - 08:17 AM
supergee, on 01 May 2012 - 09:36 PM, said:
@garyracer513 - ... Thanks!
Who's Gary?
  • supergee
Posted 02 May 2012 - 09:13 PM
:banghead:
grayracer513
