I cannot get the fuel screw to respond on my 96 XR200R. The carb is spottless, however when I put a rebuild kit in it I noticed the taperered end of the fuel screw was damaged. The end was slightly mushroomed and had a slight bend to it.
How easy is it to damage the body using a bent screw?
Is there any way to check if the seating area is damaged?
Has anyone seen a damaged one, and what were the symptoms?
Is ebay the best bet on sourcing a used kiehin body?
What are the chances that the carb body was damaged from bent airscrew
Started by
Azjakeh
, May 01 2012 08:13 AM
6 replies to this topic
Posted 01 May 2012 - 11:54 AM
If the screw tip is damaged then the chances are high that the carb body is also damaged. There is a slim chance you might get by setting the screw out less that called for. Say the manual states the screw should be set at 1 1/2 turns out you might find that setting the screw out at say 1 1/4 or 1 1/8 turns will work. Keep your fingers crossed that will work.
Posted 01 May 2012 - 01:02 PM
I would try replacing the screw. It is softer material than the carb body.
Be sure you have all the washers and O ring when you put the new one in.
Could have been that they were missing and someone screwed it way in to compensate for the air leak.
Posted 01 May 2012 - 01:27 PM
I ordered a used body off ebay, and a kit from winncycles. It should be here Friday.
It is like there is near zero adjustability in the pilot circut. I've been chasing my tail on it all week
, so now I will throw some parts at it and see what happens.
Thanks, Jake
Thanks, Jake
Posted 01 May 2012 - 01:31 PM
I agree that a missing O ring may have caused an air leak. Carb bodies are either a pot metal or aluminum, both are soft and easily damaged.
Posted 07 May 2012 - 06:47 PM
i dont think the carb body is damaged becuase the needle is brass which is softer than the carb so what will bend is the needle
