clutch starter gear
2 replies to this topic
  • cade_b
Posted 01 May 2012 - 07:32 AM
ok I have the starter gear figured out but I have a question on the primary drive gear. it has some odd wear on it should I be concerned or just run it as it is 2009 ttr 125le  http://i1100.photobu..._b/DSCN1932.jpg http://i1100.photobu..._b/DSCN1933.jpg
thanks for the help
cade
Edited by cade_b, 01 May 2012 - 11:09 AM.
  • Punkinhead
Posted 02 May 2012 - 08:41 PM
If it were me, I'd want to figure out what caused it to make sure it doesn't happen again or get worse.  Often times, gears are just case-hardened, rather than through-hardened, and once the surface is compromised, they can wear in a hurry.  That being said, it doesn't look like the surface that bears the load has been damaged, but I would replace the gear to be safe (I'll admit that I'm picky, though).  Don't just slap a new one in there.  Try to figure out the cause so you don't ruin a new gear.
  • cade_b
Posted 03 May 2012 - 09:24 PM
thanks for the help ill get it taken apart and see whats going on
thanks again
