Best first mod (crf230f)
11 replies to this topic
  • Drew.P
Posted 29 April 2012 - 05:10 PM
What's the best first mod for my 230 to make it faster?
  • 12bruckd
Posted 29 April 2012 - 05:15 PM
to make it faster you could put a smaller sprocket on the back to increase top speed, but torque would be reduced...
  • n2omike
Posted 29 April 2012 - 05:45 PM
Jet the carb, remove the intake snorkel and modify the exhaust.  But, do not remove the snorkel without jetting the carb.
  • BrandonPley
Posted 29 April 2012 - 06:04 PM
check list for bike to be good:
#1) Jet carb and baffe/snorkle mod
#2) suspension
that is all.. unless you want to get crazy :banghead:
  • Toast
Posted 29 April 2012 - 06:33 PM
#2) suspension
that is all.. unless you want to get crazy :thumbsup:
What he said! :banghead:
It's debatable on the order though.   You'll be faster with good suspension, period, but uncork and rejet is cheap, cheap, cheap.  So, why not do it.
Suspension gets pricey but worth every penny if speed is your goal.
Taller handle bars wont make you faster but will help you stand up on this little bike.  Which is a good thing.  If you're taller than 5' 5"  you'll benefit from taller bars.
Edited by Toast, 29 April 2012 - 06:36 PM.
  • Confederate
Posted 30 April 2012 - 03:01 AM
First you must ride,ride, ride. Then when the bike seems slow you can modify. So the first thing is to jet it properly, because it is slow right out of the box. The Mike Coe jetting specs are the way to go. You can find what parts you need in this forum. Vortec CPI has alot of post on this subject. You won't be displeased it makes it feel like a whole new bike.
  • HondaPowered
Posted 30 April 2012 - 03:58 AM
cut airbox, remove the baffle and add a JD or a dynojet kit. these three things will make it seem like a new bike but will also expose how bad the stock tires are.
  • Toast
Posted 30 April 2012 - 06:44 PM
You don't cut the airbox on these bikes.  You just need to pull the snorkel / baffle.  Gives 4 times the area for flow
There is no JD kit for these bikes.
Interesting though there is a dynojet jetting kit: http://www.dynojet.com/pdf/1176.pdf
  • HondaPowered
Posted 01 May 2012 - 04:06 AM
i got the dynojet kit and it worked great very good instruction on what jets to use in all situations.
  • 230Fstroker
Posted 01 May 2012 - 01:21 PM
As everyone has stated above.
Exhaust and jetting is best first mod. Only thing for me is now I'm addicted, I want more.
Once you feel the difference you'll want to go even faster and at the sametime want the bike to handle better. So in my case suspension is in the works, pieces are comming.
Gotta have it. :banghead:
  • Skillz954
Posted 11 May 2012 - 12:41 PM
Honestly the best upgrade I did to my crf230 was getting rid of the stock pirelli tires and putting on some maxxis IT's.......power doesn't matter if you can't hook up.......the second would be doing the 428 conversion.....frees so much wiehgt up from your final drive....very noticable!!
  • 230Fstroker
Posted 11 May 2012 - 01:12 PM
Lots of comments on here about the 428 conversion, such as it's a waist of money and so on.
Good to here from a someone that actually has the conversion.
I'm working on my rear suspension right now and will most likely add the conversion to my project.
If your going to make her go make her go right?
Edited by 230Fstroker, 11 May 2012 - 01:14 PM.
