2007 yz450f valve adjustment or replace?
5 replies to this topic
  • Family Man
Posted April 29, 2012 - 04:11 PM
I likely have thousands of hours on my 07 yz450f and it wont kick start anymore. Maybe it will start if I kick it for 30 mins plus. However, it runs once bump started, and will restart once warmed up. it does feel tired with low compression. Today, I measured the valves at top dead center as per manual, the exhuast valves are both at .20mm and I cant even get a feeler into any of the intakes. I have a new timing chain coming Monday, was thinking maybe it stretched a tad and for preventative.
  • RiderX
Posted April 29, 2012 - 04:23 PM
If you really have "thousands" of hours on your bike and you're still on the factory top end I think it's time for new valves, piston, and probably a replated or new cylinder. While the top end is off check the rod bearing for play as well.
  • Family Man
Posted April 29, 2012 - 04:33 PM
I have replace the piston, rings, wristpin, circlips, and timing chain once before.
  • Family Man
Posted April 29, 2012 - 04:37 PM
I might sell it cheap as is, maybe 1500 or so. I do have tons of time on it so Im kinda attached to it. It may just be roached.
  • Family Man
Posted April 29, 2012 - 04:39 PM
I bet your right and it probley need all those things. I was thinking it would be easier to sell if it started.
  • RiderX
Posted April 29, 2012 - 05:23 PM
Barring other problems with the bike it will start much easier with the valves adjusted. If you're just going to turn around and sell it I wouldn't sink money into it.
  • 3 replies
  • Hot  38 replies
  • Hot  50 replies
