07 yfz, Ran good then all of the sudden stopped having spark. I have went through all of the connections, cleaned with electrical cleaner, all grounds are good, fuses arnt blown, and still no spark. I have another running yfz I tried swapping the cdi box, rectifier, and coil. Other then that my 05 doesnt have the same connections as the on/off switch or the same resistor. Could it be the resistor, stator, how do i go about testing.
Help is needed asap.
Thanks
YFZ spark
Started by
2strokeFTW
, Apr 29 2012 03:40 PM
3 replies to this topic
Posted 29 April 2012 - 05:01 PM
im not sure exactly on procedures but you can use an electrical tester to measure ohms and volts and stuff to see if things are working correctly. try doing a search to look on how to test it.
Posted 29 April 2012 - 07:29 PM
I ended up taking a test light and trying it on 2 of the wires coming from the stator. One of them should have power going through it as I crank it over. Niether had a light nor blinked. Gues its time to start searching for a stator.
Yamaha
2002 warrior 350ATV/UTV → Make/Model Specific → Sport ATV |
Yamaha
'01 Big Bear rear oil leak & a question or two.........ATV/UTV → Make/Model Specific → Utility ATV |
Yamaha
87 Yamaha Warrior YFM, Igntion Sparks when Ignition Off, No Spake when ONATV/UTV → Make/Model Specific → Sport ATV |
Yamaha
yamaha blaster wont runATV/UTV → Make/Model Specific → Sport ATV |
Yamaha
600 Grizzly no sparkATV/UTV → Make/Model Specific → Utility ATV |
